Contacts not shown in web frontend
  1. open contacts in web frontend
all contacts should get listet
none are listed in the web-app.
But they are in the database. And they are in the Webdav-Export and they are visible in other frontends using Webdav.
Debian 9
Apache 2.4
10.1.26-MariaDB-0+deb9u1
5.6.30-0+deb8u1
9.0.10 (production)
Updated
Integrity checker has been disabled. Integrity cannot be verified.
“system”: {
“instanceid”: “51121a6156e42”,
“datadirectory”: “/var/www/diewolke/data”,
“dbtype”: “mysql”,
“version”: “9.0.10.2”,
“dbname”: “diewolke”,
“overwritewebroot”: “/diewolke”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“installed”: true,
“ldapIgnoreNamingRules”: false,
“theme”: “”,
“maintenance”: false,
“trusted_domains”: [
INTERNAL*”
“forcessl”: true,
“overwrite.cli.url”: “/diewolke”,
“loglevel”: 0
Enabled:
  • activity: 2.2.1
  • calendar: 1.4.1
  • comments: 0.2
  • configreport: 0.1.1
  • contacts: 1.5.1
  • dav: 0.1.6
  • federatedfilesharing: 0.1.0
  • federation: 0.0.4
  • files: 1.4.4
  • files_locking: true
  • files_pdfviewer: 0.8.1
  • files_sharing: 0.9.1
  • files_texteditor: 2.1
  • files_trashbin: 0.8.0
  • files_versions: 1.2.0
  • files_videoplayer: 0.9.8
  • files_videoviewer: 0.1.3
  • firstrunwizard: 1.1
  • gallery: 14.5.0
  • notifications: 0.2.3
  • provisioning_api: 0.4.1
  • search_lucene: 0.6.0
  • systemtags: 0.2
  • templateeditor: 0.1
  • updatenotification: 0.1.0
    Disabled:
  • admin_dependencies_chk
  • admin_migrate
  • bookmarks
  • encryption
  • external
  • files_antivirus
  • files_archive
  • files_encryption
  • files_external
  • files_imageviewer
  • files_odfviewer
  • impress
  • media
  • tasks
  • updater
  • user_external
  • user_ldap
  • user_migrate
  • user_openid
  • user_webdavauth
  • user_webfinger
no
no
no
Firefox / Chrome
Debian
repeatetly:
[Sun Oct 29 09:58:50.522208 2017] [authz_core:error] [pid 17930] [client 10.1.1.25:47370] AH01630: client denied by server configuration: /var/www/diewolke/data/htaccesstest.txt
currently none
Using //@ to indicate sourceMappingURL pragmas is deprecated. Use //# instead[Learn More]  jquery.min.js:1
Use of getPreventDefault() is deprecated.  Use defaultPrevented instead.  jquery-1.10.2.js:5375:28
Use of getAttributeNode() is deprecated. Use getAttribute() instead.  jquery-migrate.min.js:2:1616
Use of attributes’ nodeValue attribute is deprecated. Use value instead.  jquery-migrate.min.js:2:1616
all  status 200
Did you make an update recently?
If yes - frow which version?
Updater Backup says, the version before was 8.2.11.
Unfortunately I can not tell for sure when the problem started. I use the web frontend very rarely. My typical client is the Contacts on my Android Smartphone and in Thunderbird. And they both work nicely.
So contacts on the phone and Thunderbird work but not on the web UI?
I just tested it with the other clients. Forget them. They are working on cached data.
So the interesting part is only the link…
…remote.php/dav/addressbooks/users/nobs/contacts/?export
… which shows hundreds of entries of user nobs, whereas the GUI only shows a part. As it seems it is those entries which are in a group.
I recreated the contacts from scratch from a data dump. I guess the problem was a corruption od data on DB level.
