Copy Folder Error Problem
Hello friends,
The folders in the owncloud folder create their own copies.
And it’s causing a synchronised problem.
Help me :frowning:
Thanks.
@Siesta What exact versions do you use on server and client? What is the operating system you’re running? Can you provide reliable steps to reproduce this?
@michaelstingl hello,
I’m using windows 10 operating system.
My problem,
The existing files in the owncloud share make their own copies, a second file named copy is created and this causes a synchronization error.
thanks.
Trying to help. But you need to answer my questions.
What is the exact version of the ownCloud desktop sync client you’re using?
What is the exact version of the ownCloud server you’re using?
ownCloud desktop 2.6.1 version
