Copy Paste not working
  1. I am not able to copy paste into the spreadsheet. does it have any browser compatibility issues?
  2. how many users can edit in parallel?
  3. is OwnCloud a good tool for a company with 2500+ employees?
Hi Ramesh,
Could you let us know which version of ownCloud, Collabora and browser you are using so that we can check this out?
I would imagine the number of parallel users on one document would depend on your server configuration and setup. How many would you imagine having?
Take a look at https://owncloud.com for the commercial offerings and to see some of the large customers using ownCloud within their businesses.
Cheers,
Tom
Hi Tom,
  1. We are using version 9.1.2. on google chrome/Edge/IE. Collabora version01.1.22 I also figured that I am able to copy text but not a table from Excel or Google Docs. Also, if I tried to highlight the cells, it is dragging the entire sheet and not sure if this is issue with owncloud or mine.
  2. Typically we have about 10-12 users parallel edit the document.
  3. Also and changing the UAD directory the LDAP user is not being listed. not sure if we missing anything.
