Hello
I Installed ownCloud )10.3.2 on Ubuntu 18
I tried to create users but It doesn´t work because It doesn´t create users folder
I can create users using shell prompt
Somebody knows what´s happening
Thank you
Hello
Thank you
Did you check the logs
There is a template for server issues, please fill it out so people here can help you effectively.
There are just too many variables regarding your setup, why it might not be able to create the user folder, depending on what storage backend you’re using.
Additionally can you answer the following questions:
Have/do you:
