I input the information I knew. Fresh install of version 10.0.10.
I create a PUBLIC link/URL. Then when someone tries to access it, Owncloud will prompt them for a username and password. This is a PUBLIC link I’m creating. I do not want Owncloud to prompt the user for credentials.
A box comes up and says:
The server is asking for your user name and password. The server reports this this is from Owncloud. And the pop up box header indicates Windows security.
I do remember in the previous versions this did not happen.
I hope this is the correct place for this. It is real tricky trying to find the correct forums area since there is Owncloud Enterprise out there as well. Well, I hope this can checked out or someone knows off the top of their head. Everything usually boils down to access and rights in the end.
Centos 7.6 VPS
Latest PHP - 7.1
MariaDB 10.2
10.0.10
Fresh install
Says NO ERRORS HAVE BEEN FOUND
Edited for security
<?php
$CONFIG = array (
'instanceid' => 'octo1dapkkzg',
'passwordsalt' => 'FDVyuSz',
'secret' => '+hlQyUUhqsgZnnU4t',
'trusted_domains' =>
array (
0 => 'domain.com',
'datadirectory' => '/home/domain/public_html/data',
'overwrite.cli.url' => 'http://domain.com',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'domain_owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'domain_mike',
'dbpassword' => 'mypassword',
'logtimezone' => 'UTC',
'installed' => true,
**List of activated apps:**
Gallery
Guests
No
No
No
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
Chrome 70
**Operating system:**
Windows 10
### Logs
#### Web server error log
#### Browser log
c) …
