Cron blocks my raspberry pi
Hi
I’ve installed owncloud 10 on a raspberry pi 3b.
It is running on apache2, mysql, redis, php7, jessie. It is serving 4 different SMB CIFS shares; 3 x 4tb (1 of them is mostly fulfilled with movies, the rest is general files: docx, pdf, indd, psd, premiere projects) + 1 x 2 TB (general).
When I set cron to run using the system cron it makes may system unresponsive. I’ve set it to run on ajax. And the system looks ok, at least is responsive.
I’ve also saw to make occ file:scan -all through cron.
My client runs on macOS mojave and I’m experimenting virtual files, which are not all synced. I’ve had issues configuring the external shares, so now I’m waiting to complete all the scanning.
Per example my client log tonight:
17/02/2019 23:38:17, FOLDER ,An error occurred while opening a folder Arquivo/ArquivoYYYYY/ZZZ XIX/04 — Design/PROJECT_XXX: Operation canceled
Which cron tasks should be enabled? If cron makes my system unusable I think I should continue to make a task at a time using ajax (as the client also browses the system I suppose tasks continue to be done). Are there any occ commands recommendable to be done? Is there any advantage to do a regular “occ files:scan --all” ? And deletions and expiring versions? Shouldn’t it be done automatically?
paste the results into https://gist.github.com/ and puth the link here: https://gist.github.com/dawn2duskpt/59783be20706daa69668c4bfac5ba50a
“system”: {
“instanceid”: “ocsuae146qmo”,
“updater.secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“agendacultural.eu”
“datadirectory”: “/media/owncloud-usb”,
“overwrite.cli.url”: “https://agendacultural.eu/cloud”,
“dbtype”: “mysql”,
“version”: “10.0.10.4”,
“dbname”: “owncloud2”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “sendmail”,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtpauth”: 1,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “587”,
“mail_smtpsecure”: “ssl”,
“memcache.local”: “\OC\Memcache\Redis”,
“filelocking.enabled”: true,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379
“files_external_allow_create_new_local”: “true”,
“loglevel”: 3,
“versions_retention_obligation”: “30, 31”
Enabled:
  • activity: 2.4.2
  • announcementcenter: 1.2.1
  • audioplayer: 2.6.0
  • calendar: 1.6.1
  • camerarawpreviews: 0.6.4
  • comments: 0.3.0
  • configreport: 0.1.1
  • contacts: 1.5.5
  • customgroups: 0.4.0
  • dav: 0.4.0
  • external: 1.2
  • federatedfilesharing: 0.3.1
  • federation: 0.1.0
  • files: 1.5.1
  • files_external: 0.7.1
  • files_pdfviewer: 0.10.0
  • files_sharing: 0.11.0
  • files_texteditor: 2.3.0
  • files_trashbin: 0.9.1
  • files_versions: 1.3.0
  • files_videoplayer: 0.9.8
  • firstrunwizard: 1.1
  • gallery: 16.1.1
  • guests: 0.7.0
  • market: 0.3.0
  • notifications: 0.3.5
  • provisioning_api: 0.5.0
  • richdocuments: 2.1.2
  • systemtags: 0.3.0
  • updatenotification: 0.2.1
  • user_external: 0.4
    Disabled:
  • encryption
YES: SMB
NO
NO
Browser: safari
macOS mojave
maybe you had too many tasks in your queue due to the usage of Ajax which are now putting high load on your system until those are processed?
Have you tried to research from which component the high load is coming from?
Some additional things i’m seeing which could give additional performance improvements:
Have you considered to update to the recent Server 10.1.0 Release ?
I think the memcache.distributed isn’t required for your setup as long as you don’t have multiple systems accessing the same redis cache.
According to the documentation below APCu is recommended for small / home systems.
Maybe using unix sockets like described in the documentation below could avoid the overhead of a TCP connection:
Hi.
Thanks. I’ve read on owncloud doc that for small systems with small amounts of memory using Redis for all cache is recommended.
About memcache.distributed i’ve 4 devices accessing the owncloud server. Shouldn’t I use this option?
About latest version, I wasn’t aware of this. Thanks.
I still can’t make my clients to sync using virtual files, or if they have downloaded those virtual files, then the client doesn’t download the file from the server. most of the files are on external smb shares.
Thanks.
i don’t think that this is the correct assumption. From what i know this is not about the devices accessing the server but a distributed setup of more then one ownCloud server connecting to the same redis cache.
Hum… ok, so i Should turn it off, right? It is one server on one raspberry pi. It serves several php webpages and a email server also (davecot).
