- I have changed the cron configuration in the owncloud Admin Area from Ajax to cron.
- Added a new cron job following the instructions from https://doc.owncloud.org/server/10.6/admin_manual/configuration/server/background_jobs_configuration.html:
# sudo crontab -u www-data -e
* * * * * /usr/bin/php -f /path/to/your/owncloud/occ system:cron
It should run cron every minute.
The email received from the Activity app, doesn’t show the custom logo anymore, and the URL to the owncloud is not right, instead every file links to an URL like this one: http://localhost/index.php/f/14879
Ubuntu 18.04.5 LTS
Apache/2.4.29 (Ubuntu)
Server version: 10.5.9-MariaDB-1:10.5.9+maria~bionic mariadb.org binary distribution
PHP 7.4.16 (cli) (built: Mar 5 2021 07:54:20) ( NTS )
Copyright © The PHP Group
Zend Engine v3.4.0, Copyright © Zend Technologies
with Zend OPcache v7.4.16, Copyright ©, by Zend Technologies
10.7.0.4
fresh install
source
Enabled:
- activity:
- Version: 2.6.0
- calendar:
- Version: 1.6.4
- Path: /var/www/owncloud/apps-external/calendar
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.0
- contacts:
- Version: 1.5.5
- Path: /var/www/owncloud/apps-external/contacts
- dav:
- Version: 0.6.0
- federatedfilesharing:
- Version: 0.5.0
- files:
- Version: 1.5.2
- files_antivirus:
- Version: 0.15.2
- Path: /var/www/owncloud/apps/files_antivirus
- files_external:
- Version: 0.7.1
- files_mediaviewer:
- Version: 1.0.4
- files_pdfviewer:
- Version: 0.12.1
- Path: /var/www/owncloud/apps-external/files_pdfviewer
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.3.0
- Path: /var/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- market:
- Version: 0.6.0
- notifications:
- Version: 0.5.2
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- templateeditor:
- Version: 0.4.0
- Path: /var/www/owncloud/apps/templateeditor
- theme-sintas:
- Version: 1.0.0
- Path: /var/www/owncloud/apps-external/theme-sintas
- updatenotification:
- Version: 0.2.1
Disabled:
- admin_audit:
- Path: /var/www/owncloud/apps/admin_audit
- announcementcenter:
- Path: /var/www/owncloud/apps/announcementcenter
- customgroups:
- Path: /var/www/owncloud/apps/customgroups
- encryption:
- enterprise_key:
- Path: /var/www/owncloud/apps/enterprise_key
- external:
- federation:
- files_classifier:
- Path: /var/www/owncloud/apps/files_classifier
- files_external_dropbox:
- Path: /var/www/owncloud/apps/files_external_dropbox
- files_external_ftp:
- Path: /var/www/owncloud/apps/files_external_ftp
- files_ldap_home:
- Path: /var/www/owncloud/apps/files_ldap_home
- files_lifecycle:
- Path: /var/www/owncloud/apps/files_lifecycle
- firewall:
- Path: /var/www/owncloud/apps/firewall
- graphapi:
- Path: /var/www/owncloud/apps/graphapi
- guests:
- Path: /var/www/owncloud/apps/guests
- metrics:
- Path: /var/www/owncloud/apps/metrics
- oauth2:
- Path: /var/www/owncloud/apps/oauth2
- openidconnect:
- Path: /var/www/owncloud/apps/openidconnect
- password_policy:
- Path: /var/www/owncloud/apps/password_policy
- ransomware_protection:
- Path: /var/www/owncloud/apps/ransomware_protection
- sharepoint:
- Path: /var/www/owncloud/apps/sharepoint
- systemtags_management:
- Path: /var/www/owncloud/apps/systemtags_management
- theme-enterprise:
- Path: /var/www/owncloud/apps/theme-enterprise
- user_external:
- user_ldap:
- Path: /var/www/owncloud/apps/user_ldap
- user_shibboleth:
- Path: /var/www/owncloud/apps/user_shibboleth
- windows_network_drive:
- Path: /var/www/owncloud/apps/windows_network_drive
- wopi:
- Path: /var/www/owncloud/apps/wopi
- workflow:
- Path: /var/www/owncloud/apps/workflow
no
