i have a problem with the ownlcoud desktop client (version 2.9.1). If i want to create a new public link, the client shows me “CSRF check failed”. I tried to use the ‘csrf.disabled’ => false, option in the config.ini but it does not work.
Usually this means some Apache PHP modules are missing:
CSRF check failed when trying to share files - #13 by corby
i checked this, every moduls active. AllowOverride All is configured.
i tried ‘csrf.disabled’ => true,’ in config.php. It works but than the client stop working with “599 Broken”
