cURL 60 certificate issue with appstore
I can´t access the appstore anymore. worked 3 days ago.
I am getting curl: (60) SSL certificate problem: unable to get local issuer certificate
same for a local $ curl -i https://apps.owncloud.com
also
wget https://apps.owncloud.com
--2016-11-22 20:26:33--  https://apps.owncloud.com/
Auflösen des Hostnamen »apps.owncloud.com (apps.owncloud.com)«... 69.64.55.83
Verbindungsaufbau zu apps.owncloud.com (apps.owncloud.com)|69.64.55.83|:443... verbunden.
FEHLER: Dem Zertifikat von »apps.owncloud.com« wird nicht vertraut.
FEHLER: Das Zertifikat von »»apps.owncloud.com«« wurde von einem unbekannten Austeller herausgegeben.
also on your sides?
Yes, noticed the same today. Seems apps.owncloud.com got moved to Let’s Encrypt but they have currently some issues with the certificate chain:
https://www.ssllabs.com/ssltest/analyze.html?d=apps.owncloud.com
and I was freaking out on what got messed up on my raspberry.
so no issue with me
I also thought it has something to do with my server initially as Firefox was happily able to access https://apps.owncloud.com. Don’t know why wget and curl are don’t accepting a connection.
The issue has been fixed and the appstore is now available again:
https://github.com/owncloud/owncloud.org/issues/1105
hello,
still does not work for me.
when I do a curl -i https://apps.owncloud.com everything looks ok.
but the store accesses
https://api.owncloud.com - and here it still brings this error
curl -i https://api.owncloud.com
Ahhh, api.owncloud.com is a different server which still has this issue:
@RealRancor any updates?
@Rello You can check that on your own at untrusted certificate on apps.owncloud.com · Issue #1105 · owncloud-archive/owncloud.org · GitHub :slight_smile:
I don’t have any contact to people which might be able to fix this outside of github.
So it got solved a few minutes ago:
works :slight_smile:
