Hi
I am running OC 10.0.6 and I’m trying to use the updater to upgrade to v10.0.8 but I am receiving this error:
cURL error 6: Could not resolve host: myhostname.com
I did recently change my external dns name, can this be why I’m getting this error?
Hi
Can you upgrade manually? That’s the recommended way to go.
while i think manually upgrading is the best option this probably should be fixed as well:
I found the following document:
https://curl.haxx.se/libcurl/c/libcurl-errors.html
which seems to note the following for the error message:
Couldn’t resolve host. The given remote host was not resolved.
Both, the message and the error looks to me indeed like an DNS issue on your server.
I guess instead of trying to fix this issue ill have to try and manually upgrade OC.
