Hello, We built ownCloud desktop client, it works nicely, but there’s no Frameworks folder in our build. What I mean is:
Go to /Applications/owncloud.app/Contents and you will see there’s a folder called “Frameworks” which includes:
- QtConcurrent.framework
- QtCore.framework
- QtDBus.framework
- QtGui.framework
- QtMacExtras.framework
- QtNetwork.framework
- QtPrintSupport.framework
- QtSvg.framework
- QtWidgets.framework
- QtXml.framework
- Sparkle.framework
But in my build I don’t have Frameworks folder, oddly, the app works, but I think it creates problems when we try to code sign the app and package. What do you think? Is app working because I have *.framework frameworks in the computer I did the building process and not work on a Mac with no Qt packages?
This one is a hard problem to solve because I can’t find a soft place to start digging the problem. Thanks guys.
