an user of my cloud told me, that he couldn’t create an event in a shared calendar. When I logged in as normal user (the one, that created the calendar and shared it with a group), I noticed that my calendars were completely missing and only the “loader circle” was shown on the left. Connecting to WebDAV via command line with cadaver and changing into calendars/${USERNAME} showed the calendars I’ve created including the shared one:
root@serverX:/data/owncloud# cadaver
dav:!> open https://www.mydomain.de/owncloud/remote.php/dav/
Authentication required for Cloud on server `www.mydomain.de':
Username: ${USERNAME}
Password:
dav:/owncloud/remote.php/dav/> cd calendars/${USERNAME}
dav:/owncloud/remote.php/dav/calendars/${USERNAME}/> ls
Listing collection `/owncloud/remote.php/dav/calendars/${USERNAME}/': succeeded.
Coll: business 0 Jan 1 1970
Coll: contact_birthdays 0 Jan 1 1970
Coll: default 0 Jan 1 1970
Coll: inbox 0 Jan 1 1970
Coll: outbox 0 Jan 1 1970
Coll: shared_cal 0 Jan 1 1970
Since I updated directly from 8.x to 9.1.x I suspect that something during the update went wrong and I wanted to migrate the calendars manually but the command was not found.
So how do I now update/migrate the calendars? Or will the “dav:migrate-” commands come back with the next release?
Torsten
- cd ${OWNCLOUDDIR}
- sudo -u ${WEBSERVERUSER} php occ dav:migrate-calendars ${USERNAME}
Calendars and/or addressbooks should be migrated from 8.x to 9.x
Error message that the command “dav:migrate-calendars” is not defined
Operating system: Debian Jessie (8.5)
Web server: Apache 2.4.10-10+deb8u5
Database: SQLite3
PHP version: PHP 5.6.24+dfsg-0+deb8u1
ownCloud version (see ownCloud admin page): Owncloud 9.1.0-1.1
{“reqId”:“P9croeHtjKnRuCCIRvfm”,“remoteAddr”:“192.168.13.1”,“app”:“files”,“message”:“Exception: {"Exception":"BadMethodCallException","Message":"Not in batch","Code":0,"Trace":"#0 \/data\/owncloud\/lib\/private\/Files\/Utils\/Scanner.php(143): OC\\Files\\Cache\\Propagator->commitBatch()\n#1 \/data\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(87): OC\\Files\\Utils\\Scanner->backgroundScan(‘’)\n#2 \/data\/owncloud\/apps\/files\/lib\/BackgroundJob\/ScanFiles.php(111): OCA\\Files\\BackgroundJob\\ScanFiles->runScanner(Object(OC\\User\\User))\n#3 \/data\/owncloud\/lib\/private\/BackgroundJob\/Job.php(52): OCA\\Files\\BackgroundJob\\ScanFiles->run(NULL)\n#4 \/data\/owncloud\/lib\/private\/BackgroundJob\/TimedJob.php(53): OC\\BackgroundJob\\Job->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#5 \/data\/owncloud\/cron.php(144): OC\\BackgroundJob\\TimedJob->execute(Object(OC\\BackgroundJob\\JobList), Object(OC\\Log))\n#6 {main}","File":"\/data\/owncloud\/lib\/private\/Files\/Cache\/Propagator.php","Line":145}”,“level”:3,“time”:“2016-08-19T09:59:23+00:00”,“method”:“GET”,“url”:“/owncloud/cron.php”,“user”:“–”}
{“reqId”:“FpLKoMJklIAaBk+0X37f”,“remoteAddr”:“192.168.13.1”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 405 Listing members of this collection is disabled","Exception":"Sabre\\DAV\\Exception\\MethodNotAllowed","Code":0,"Trace":"#0 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(195): Sabre\\DAVACL\\AbstractPrincipalCollection->getChildren()\n#1 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(857): Sabre\\DAV\\Tree->getChildren(‘calendars’)\n#2 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(911): Sabre\\DAV\\Server->addPathNodesRecursively(Array, Object(Sabre\\DAV\\PropFind))\n#3 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(334): Sabre\\DAV\\Server->getPropertiesForPath(‘calendars’, Array, 1)\n#4 [internal function]: Sabre\\DAV\\CorePlugin->httpPropFind(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#5 \/data\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#6 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459): Sabre\\Event\\EventEmitter->emit(‘method:PROPFIND’, Array)\n#7 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#8 \/data\/owncloud\/apps\/dav\/lib\/Server.php(169): Sabre\\DAV\\Server->exec()\n#9 \/data\/owncloud\/apps\/dav\/appinfo\/v2\/remote.php(29): OCA\\DAV\\Server->exec()\n#10 \/data\/owncloud\/remote.php(164): require_once(‘\/data\/owncloud\/…’)\n#11 {main}","File":"\/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAVACL\/AbstractPrincipalCollection.php","Line":95,"User":"yoda"}”,“level”:4,“time”:“2016-08-19T10:01:20+00:00”,“method”:“PROPFIND”,“url”:“/owncloud/remote.php/dav/calendars/”,“user”:“${USERNAME}”}
{“reqId”:“vbJncsylWxonTQLf/+DZ”,“remoteAddr”:“192.168.13.1”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 405 Listing members of this collection is disabled","Exception":"Sabre\\DAV\\Exception\\MethodNotAllowed","Code":0,"Trace":"#0 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(195): Sabre\\DAVACL\\AbstractPrincipalCollection->getChildren()\n#1 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(857): Sabre\\DAV\\Tree->getChildren(‘calendars’)\n#2 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(911): Sabre\\DAV\\Server->addPathNodesRecursively(Array, Object(Sabre\\DAV\\PropFind))\n#3 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(334): Sabre\\DAV\\Server->getPropertiesForPath(‘calendars’, Array, 1)\n#4 [internal function]: Sabre\\DAV\\CorePlugin->httpPropFind(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#5 \/data\/owncloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#6 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(459): Sabre\\Event\\EventEmitter->emit(‘method:PROPFIND’, Array)\n#7 \/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(248): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#8 \/data\/owncloud\/apps\/dav\/lib\/Server.php(169): Sabre\\DAV\\Server->exec()\n#9 \/data\/owncloud\/apps\/dav\/appinfo\/v2\/remote.php(29): OCA\\DAV\\Server->exec()\n#10 \/data\/owncloud\/remote.php(164): require_once(‘\/data\/owncloud\/…’)\n#11 {main}","File":"\/data\/owncloud\/3rdparty\/sabre\/dav\/lib\/DAVACL\/AbstractPrincipalCollection.php","Line":95,"User":"yoda"}”,“level”:4,“time”:“2016-08-19T10:01:49+00:00”,“method”:“PROPFIND”,“url”:“/owncloud/remote.php/dav/calendars/”,“user”:“${USERNAME}”}
none
Integrity status for oC9+
paste the results here.
https://www.mydomain.de/owncloud/settings/integrity/failed
