DB data restore after manual upgrade from 8.1.3 to 10.0.4
  1. With a working owncloud 8.1.3 setup create a mysqldump as per ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company)
  2. Download download.owncloud.com into a new web directory
  3. Follow vanilla install steps through webGUI as per ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company) (creates a new DB with generic content and admin credentials)
  4. Log into the webGUI successfully using these admin credentials)
  5. Follow mysql database restore process as per the documentation ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company) (mysql -h [server] -u [username] -p[password] [db_name] < owncloud-dbbackup.bak)
  6. Try to log into the webGUI
Login to the webGUI succeeds and user credential and application data is available and accessible as it was prior to the upgrade
Login to the webGUI fails with a notification that various apps need to be updated
Trying to perform this upgrade fails with an error
Regardless of whether the upgrade is attempted through the webGUI or via
sudo -u www-data php /path/to/occ upgrade
Going deeper into the rabbit hole (following the advice to deactivate those apps)
i.e. via
for i in activity files_locking files_pdfviewer files_videoviewer updater; do sudo -u www-data php /path/to/owncloud/occ app:disable $i; done
and re-running
results in
Ubuntu 16.04.3 LTS 4.9.50-x86_64
apache2 (2.4.18-2ubuntu3.5)
mariadb-server-10.0 (10.0.31-0ubuntu0.16.04.2)
PHP Version 7.0.22-0ubuntu0.16.04.1
10.0.4
Fresh install (with attempted mysql dump restore from a 8.1.3 database)
download.owncloud.com following ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company)
<?php
$CONFIG = array (
  'instanceid' => 'xxx',
  'passwordsalt' => 'xxx',
  'secret' => 'xxx',
  'trusted_domains' =>
  array (
    0 => 'xxx',
  'datadirectory' => '/path/to/owncloud/data',
  'overwrite.cli.url' => 'https://xxx/owncloud',
  'dbtype' => 'mysql',
  'version' => '10.0.4.4',
  'dbname' => 'xxx',
  'dbhost' => 'localhost',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'xxx',
  'dbpassword' => 'xxx',
  'logtimezone' => 'UTC',
  'installed' => true,
  'theme' => '',
  'loglevel' => 2,
  'maintenance' => true,
Enabled:
  - calendar: 0.7.3
  - contacts: true
  - dav: true
  - federatedfilesharing: true
  - files: 1.1.10
  - files_external: true
  - files_sharing: 0.6.2
  - files_texteditor: 0.4
  - files_trashbin: 0.6.3
  - files_versions: 1.0.6
  - firstrunwizard: 1.1
  - gallery: 0.6.0
  - provisioning_api: 0.2
  - templateeditor: 0.1
Disabled:
  - comments
  - configreport
  - encryption
  - external
  - federation
  - files_videoplayer
  - market
  - notifications
  - systemtags
  - theme-example
  - updatenotification
  - user_external
No
No
No
firefox 57.0.3+build1-0ubuntu0.16.04.1
Ubuntu 16.04.3 LTS
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:05:21 +1000] “GET /owncloud/core/img/logo.svg HTTP/1.1” 304 201 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:05:21 +1000] “GET /owncloud/core/img/actions/confirm.svg HTTP/1.1” 304 200 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:05:21 +1000] “GET /owncloud/core/img/background.jpg HTTP/1.1” 304 202 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:05:21 +1000] “GET /owncloud/core/vendor/browser-update/browser-update.js?=1515024321446 HTTP/1.1" 200 11334 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/2010010
1 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:05:21 +1000] “GET /owncloud/cron.php HTTP/1.1” 200 772 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:45 +1000] “POST /owncloud/index.php/login HTTP/1.1” 303 5715 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:46 +1000] “GET /owncloud/index.php/apps/files/ HTTP/1.1” 200 5651 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:46 +1000] “GET /owncloud/index.php/core/js/oc.js?v=d7b98edf064f4a87fb2ffb306639e3f3 HTTP/1.1” 200 4615 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “GET /owncloud/cron.php HTTP/1.1” 200 772 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “PROPFIND /owncloud/remote.php/webdav/ HTTP/1.1” 207 3489 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 1054 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Ge
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “GET /owncloud/index.php/apps/files/ajax/getstoragestats.php?dir=%2F HTTP/1.1” 200 937 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/201001
01 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “GET /owncloud/index.php/avatar/admin/28 HTTP/1.1” 200 983 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:47 +1000] “GET /owncloud/index.php/apps/gallery/config?extramediatypes=1 HTTP/1.1” 200 1008 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Fi
refox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:56 +1000] “GET /owncloud/index.php/settings/users HTTP/1.1” 200 4823 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:56 +1000] “GET /owncloud/index.php/core/js/oc.js?v=d7b98edf064f4a87fb2ffb306639e3f3 HTTP/1.1” 200 4615 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:57 +1000] “GET /owncloud/cron.php HTTP/1.1” 200 772 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:57 +1000] “GET /owncloud/index.php/settings/users/users?offset=0&limit=200&gid=&pattern= HTTP/1.1” 200 1355 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:57 +1000] “GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 1054 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:57 +1000] “GET /owncloud/index.php/settings/users/stats HTTP/1.1” 200 921 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:59 +1000] “GET /owncloud/index.php/logout?requesttoken=BlFhGHA3RDxeYxU8ejdXN0FdAHk%2BNkRUHSc1JyYGCBs%3D%3Abd9hEzqE7/BTOQ8Bt/tJXYsadFcNVONUQcWOEJADnB0%3D HTTP/1.1” 303 1583 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:10:59 +1000] “GET /owncloud/index.php/login HTTP/1.1” 200 2929 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:11:00 +1000] “GET /owncloud/index.php/core/js/oc.js?v=d7b98edf064f4a87fb2ffb306639e3f3 HTTP/1.1” 200 3661 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:11:00 +1000] "GET /owncloud/core/vendor/browser-update/browser-update.js?
=1515024660364 HTTP/1.1” 200 11334 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:11:00 +1000] “GET /owncloud/cron.php HTTP/1.1” 200 772 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:13:34 +1000] “POST /owncloud/index.php/login HTTP/1.1” 200 2892 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:13:34 +1000] “GET /owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e HTTP/1.1” 503 7530 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:15:08 +1000] “GET /owncloud/core/ajax/update.php?requesttoken=ImIBGHc%2FUR1HeA1Ef28AAQYhIj4lKGkBX2cPPQVkKQA%3D%3Ai0Uk6Lbm30kw%2F7LK0jeJNaZRj6xxIUodsYR8LTc%2F0NA%3D HTTP/1.1” 200 2625 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:16:17 +1000] “GET /owncloud/index.php/login HTTP/1.1” 200 7492 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:16:17 +1000] “GET /owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e HTTP/1.1” 503 7530 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:16:48 +1000] “GET /owncloud/index.php/login HTTP/1.1” 200 2892 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:16:49 +1000] “GET /owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e HTTP/1.1” 503 7530 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:22:38 +1000] “GET /owncloud/index.php/login HTTP/1.1” 503 12457 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - - [04/Jan/2018:10:22:39 +1000] “GET /owncloud/core/js/maintenance-check.js?v=5001bd3b523bc0efb416ad9a0768e18e HTTP/1.1” 200 879 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
xxx.xxx.xxx.xxx - user [04/Jan/2018:10:22:39 +1000] “GET /owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e HTTP/1.1” 200 3335 “-” “Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0”
{“reqId”:“ALmnZHyGlzh8IXInA6Hp”,“level”:3,“time”:“2018-01-04T00:13:34+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/legacy\/app.php(128): OC_App::loadApp(‘files’)\n#1 \/path\/to\/owncloud\/lib\/private\/legacy\/util.php(145): OC_App::loadApps(Array)\n#2 \/path\/to\/owncloud\/lib\/base.php(928): OC_Util::setupFS()\n#3 \/path\/to\/owncloud\/index.php(56): OC::handleRequest()\n#4 {main}","File":"\/path\/to\/owncloud\/lib\/private\/legacy\/app.php","Line":192}”}
{“reqId”:“dzRyoxdY5QlP6aCYpQio”,“level”:0,“time”:“2018-01-04T00:15:08+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/owncloud/core/ajax/update.php?requesttoken=ImIBGHc%xxx%3D%3Ai0Uk6Lbm30kw%2F7LK0jeJNaZRj6xxIUodsYR8LTc%2F0NA%3D”,“message”:“starting upgrade from 10.0.4.4 to 10.0.4.4”}
{“reqId”:“dzRyoxdY5QlP6aCYpQio”,“level”:3,“time”:“2018-01-04T00:15:08+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/owncloud/core/ajax/update.php?requesttoken=ImIBGHc%xxx%3D%3Ai0Uk6Lbm30kw%2F7LK0jeJNaZRj6xxIUodsYR8LTc%2F0NA%3D”,“message”:“Exception: {"Exception":"OC\\RepairException","Message":"Upgrade is not possible","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/Repair.php(88): OC\\Repair\\Apps->run(Object(OC\\Repair))\n#1 \/path\/to\/owncloud\/lib\/private\/Updater.php(221): OC\\Repair->run()\n#2 \/path\/to\/owncloud\/lib\/private\/Updater.php(108): OC\\Updater->doUpgrade(‘10.0.4.4’, ‘10.0.4.4’)\n#3 \/path\/to\/owncloud\/core\/ajax\/update.php(190): OC\\Updater->upgrade()\n#4 {main}","File":"\/path\/to\/owncloud\/lib\/private\/Repair\/Apps.php","Line":196}”}
{“reqId”:“q2WK8yZe402HSztBe4Je”,“level”:3,“time”:“2018-01-04T00:16:17+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/legacy\/app.php(128): OC_App::loadApp(‘files’)\n#1 \/path\/to\/owncloud\/lib\/private\/legacy\/util.php(145): OC_App::loadApps(Array)\n#2 \/path\/to\/owncloud\/lib\/base.php(928): OC_Util::setupFS()\n#3 \/path\/to\/owncloud\/index.php(56): OC::handleRequest()\n#4 {main}","File":"\/path\/to\/owncloud\/lib\/private\/legacy\/app.php","Line":192}”}
{“reqId”:“nbo7Df2OzrNQtNrQF5Ll”,“level”:3,“time”:“2018-01-04T00:16:49+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/owncloud/index.php/core/js/oc.js?v=5001bd3b523bc0efb416ad9a0768e18e”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/legacy\/app.php(128): OC_App::loadApp(‘files’)\n#1 \/path\/to\/owncloud\/lib\/private\/legacy\/util.php(145): OC_App::loadApps(Array)\n#2 \/path\/to\/owncloud\/lib\/base.php(928): OC_Util::setupFS()\n#3 \/path\/to\/owncloud\/index.php(56): OC::handleRequest()\n#4 {main}","File":"\/path\/to\/owncloud\/lib\/private\/legacy\/app.php","Line":192}”}
{“reqId”:“nnhs2kepYVEndozarq3f”,“level”:0,“time”:“2018-01-04T00:17:19+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“starting upgrade from 10.0.4.4 to 10.0.4.4”}
{“reqId”:“nnhs2kepYVEndozarq3f”,“level”:3,“time”:“2018-01-04T00:17:19+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“Exception: {"Exception":"OC\\RepairException","Message":"Upgrade is not possible","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/Repair.php(88): OC\\Repair\\Apps->run(Object(OC\\Repair))\n#1 \/path\/to\/owncloud\/lib\/private\/Updater.php(221): OC\\Repair->run()\n#2 \/path\/to\/owncloud\/lib\/private\/Updater.php(108): OC\\Updater->doUpgrade(‘10.0.4.4’, ‘10.0.4.4’)\n#3 \/path\/to\/owncloud\/core\/Command\/Upgrade.php(254): OC\\Updater->upgrade()\n#4 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Command\/Command.php(262): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#5 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(826): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(189): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#7 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(120): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#8 \/path\/to\/owncloud\/lib\/private\/Console\/Application.php(162): Symfony\\Component\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#9 \/path\/to\/owncloud\/console.php(106): OC\\Console\\Application->run()\n#10 \/path\/to\/owncloud\/occ(11): require_once(‘\/path\/to\/publi…’)\n#11 {main}","File":"\/path\/to\/owncloud\/lib\/private\/Repair\/Apps.php","Line":196}”}
{“reqId”:“nH6xqYPgNqjdCJ3qxTGe”,“level”:0,“time”:“2018-01-04T00:22:49+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“starting upgrade from 10.0.4.4 to 10.0.4.4”}
{“reqId”:“nH6xqYPgNqjdCJ3qxTGe”,“level”:3,“time”:“2018-01-04T00:22:49+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“Exception: {"Exception":"Exception","Message":"An exception occurred while executing ‘INSERT INTO oc_jobs (class, argument, last_run, last_checked) VALUES(?, ?, ?, ?)’ with params [\"\\\\OC\\\\Authentication\\\\Token\\\\DefaultTokenCleanupJob\", \"null\", 0, 1515025369]:\n\nSQLSTATE[42S22]: Column not found: 1054 Unknown column ‘last_checked’ in ‘field list’","Code":0,"Trace":"#0 \/path\/to\/owncloud\/lib\/private\/Updater.php(108): OC\\Updater->doUpgrade(‘10.0.4.4’, ‘10.0.4.4’)\n#1 \/path\/to\/owncloud\/core\/Command\/Upgrade.php(254): OC\\Updater->upgrade()\n#2 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Command\/Command.php(262): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#3 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(826): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#4 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(189): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#5 \/path\/to\/owncloud\/lib\/composer\/symfony\/console\/Application.php(120): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/path\/to\/owncloud\/lib\/private\/Console\/Application.php(162): Symfony\\Component\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#7 \/path\/to\/owncloud\/console.php(106): OC\\Console\\Application->run()\n#8 \/path\/to\/owncloud\/occ(11): require_once(‘\/path\/to\/publi…’)\n#9 {main}","File":"\/path\/to\/owncloud\/lib\/private\/Updater.php","Line":229}”}
So my question is:
What’s the recommended (and working) way to restore the data from a 8.1.3 mysql DB dump into the freshly created 10.0.4 DB?
Is there a DB migration process / step / script that I have overlooked?
Thanks a lot in advance,
daebi
