De que forma puedo recuperar el acceso a owncloud
Juan,
Unfortunately you did not elaborate on how you are accessing your ownCloud and which type of access you want to get back. Please consider providing some background information in the future, so somebody can actually help you.
Nevertheless, did you read the documentation? There are articles about password resets for admins and simple users: https://doc.owncloud.com/server/admin_manual/configuration/user/
If this is not, what you was asking about, please make clear what you actually want to achieve.
tenemos instalado en owncloud dentro de un servidor con proxmox y la maquina ya la subimos pero no nos permite autenticar con ningun usuario de los que estaban creados en owncloud ni administradores ni usuarios basicos no hemos podido restablecer contraseña
