Steps to reproduce 1. Test download/upload speed 2. Move several large video files from server to desktop using client app 3. Check download speeds by hovering over the sync button
Expected behaviour Should be downloading and uploading files at ~30MB/s and ~10MB/s (low estimates), optimising network speed
Actual behaviour Download speed of 500kb/s, upload of 200kb/s. Initial speeds show normal download and upload speed but this rapidly decreases. Tested on multiple networks (wired and wireless)
This should be faster on older OC versions as well. Can you see the load of your server to find the bottleneck? If you have a fast network connection to your server, you might want to try a higher chunk size (the default size of 5 MB creates a lot of chunks for large files): https://doc.owncloud.org/desktop/2.3/advancedusage.html
