Please fill out the template:
- Open desktop or web client - owncloud
- Click Share
- Select user for sharing
File gets shared with other user, and it is usable
File gets “shared” but users can’t open it, and error on share action
Operating system :
CentOS Linux release 7.5.1804 (Core)
Server version: Apache/2.4.6 (CentOS)
Server built: Jun 27 2018 13:48:59
MySQL Ver 15.1 Distrib 5.5.60-MariaDB
PHP 7.0.32 (cli) (built: Sep 15 2018 07:54:46) ( NTS )
ownCloud 10.0.10 (production)
Fresh install
Downloaded from site, installed by manual from owncloud.org
$CONFIG = array (
'instanceid' => 'ociyp4ky3ycxa67t', 'passwordsalt' => 'r7O/qe3ITu7RVEZmKNMbC5OY6/px3q', 'secret' => 'VDgv54rso8dSOwNVRnHFHmLXIVbF6GGfvp6XIWqwD1JcftQT', 'trusted_domains' => array ( 0 => ‘owncloud.##.##', ), 'datadirectory' => '/var/www/oc_data/', 'overwrite.cli.url' => 'https://owncloud.##.##', 'dbtype' => 'mysql', 'version' => '10.0.10.4', 'dbname' => 'owncloud', 'dbhost' => 'localhost', 'dbtableprefix' => 'oc_', 'dbuser' => 'oc_admin', 'dbpassword' => ‘*******', 'installed' => true, 'enable_certificate_management' => true, 'forcessl' => true, 'forceSSLforSubdomains' => true, 'mail_from_address' => 'no-reply', 'mail_smtpmode' => 'smtp', 'mail_domain' => ‘##.##', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpauth' => 1, 'mail_smtphost' => ’********', 'mail_smtpport' => '465', 'mail_smtpname' => ‘********', 'mail_smtppassword' => ‘******', 'mail_smtpsecure' => 'ssl', 'theme' => '', 'loglevel' => 3, 'maintenance' => false, 'trashbin_retention_obligation' => 'auto', 'encryption' => ‘enable', 'updater.secret' => '$2y$10$0RfIq6A7vBTvGBhnzJoc/eVSorl/B9TTpH5JqxHiy5gEeevf0bF9e', 'singleuser' => false, 'updatechecker' => false, 'filelocking.enabled' => true, 'data-fingerprint' => '713cad8ece352120658a18186b10ce30',);
- dav: 0.4.0
- encryption: 1.3.1
- federatedfilesharing: 0.3.1
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.11.0If you have access to your command line run e.g.:
Are you using external storage, if yes which one: NO
Are you using encryption: yes
Are you using an external user-backend, if yes which one: NO
Firefox, Safari, Chrome
Windows, OSX
No errors
{“reqId”:“2d96420c-ed0c-40c9-ac2d-351246b93139”,“level”:4,“time”:“2018-12-06T12:23:30+00:00”,“remoteAddr”:“192.168.11.82”,“user”:“maja.savic”,“app”:“webdav”,“method”:“PUT”,“url”:"/remote.php/dav/files/maja.savic/SNIZENJE%202018/SNIZENJE%20PL%2018/Sni%C5%BEenje%20PL18%20VI%20krug.xls",“message”:“Exception: HTTP/1.1 503 Encryption not ready: multikeydecrypt with share key failed:error:0407109F:rsa routines:RSA_padding_check_PKCS1_type_2:pkcs decoding error: {“Exception”:“Sabre\\DAV\\Exception\\ServiceUnavailable”,“Message”:“Encryption not ready: multikeydecrypt with share key failed:error:0407109F:rsa routines:RSA_padding_check_PKCS1_type_2:pkcs decoding error”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/apps\/dav\/lib\/Connector\/Sabre\/File.php(234): OCA\\DAV\\Connector\\Sabre\\File->convertToSabreException(Object(OCA\\Encryption\\Exceptions\\MultiKeyDecryptException))\n#1 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(1129): OCA\\DAV\\Connector\\Sabre\\File->put(Resource id #458)\n#2 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(513): Sabre\\DAV\\Server->updateFile(‘files\/maja.savi…’, Resource id #458, NULL)\n#3 [internal function]: Sabre\\DAV\\CorePlugin->httpPut(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/var\/www\/html\/lib\/composer\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#5 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(479): Sabre\\Event\\EventEmitter->emit(‘method:PUT’, Array)\n#6 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#7 \/var\/www\/html\/apps\/dav\/lib\/Server.php(298): Sabre\\DAV\\Server->exec()\n#8 \/var\/www\/html\/apps\/dav\/appinfo\/v2\/remote.php(31): OCA\\DAV\\Server->exec()\n#9 \/var\/www\/html\/remote.php(165): require_once(’\/var\/www\/html\/a…’)\n#10 {main}",“File”:"\/var\/www\/html\/apps\/dav\/lib\/Connector\/Sabre\/File.php",“Line”:685}"}
#### Browser log
a) No errors in console log
b) No errors in network log
