Decryption failed without error
sudo -u apache php ./occ encryption:enable
sudo -u apache php ./occ encryption:decrypt-all
I’d expect all files to be decrypted
I’m sure this is old… the files seem to be base64 encoded rather than the newer binary which seems to have been decoded.
It seems the file is ignored and considered as being succesfully decrypted.
These did not get decoded
HBEGIN:cipher:AES-256-CFB:HEND
These got decoded:
HBEGIN:oc_encryption_module:OC_DEFAULT_MODULE:cipher:AES-256-CTR:signed:true:encoding:binary:HEND
Both have ----- padding 'till the 8192 mark.
IMG_4180.JPG: ASCII text, with very long lines (65536), with no line terminators
5ae05120363e8b5ab48b2993e4577495632f59d0f7fdaeaa7e027641e87e6abb  IMG_4180.JPG
$ sudo -u apache php ./occ encryption:enable
Encryption enabled
Default module: OC_DEFAULT_MODULE
$ sudo -u apache php ./occ encryption:decrypt-all
Disable server side encryption... done.
You are about to start to decrypt all files stored in your ownCloud.
It will depend on the encryption module and your setup if this is possible.
Depending on the number and size of your files this can take some time
Please make sure that no user accesses their files during this process!
Do you really want to continue? (y/n) y
prepare encryption modules...
 done.
 %message%
Prepare "Default encryption module"
Configuring encryption module for decryption with user based keys
 decrypt files for user dexter (1 of 1): /dexter/files/Photos/XXXREDACTEDXXX/IMG_4181.JPG
 starting to decrypt files... finished
all files could be decrypted successfully!
$ dd if=IMG_4180.JPG bs=8192 count=1
HBEGIN:cipher:AES-256-CFB:HEND--------------.....
Operating system: Gentoo
Web server: Apache 2.4.52
Database: mariadb 10.5.13
PHP version: 7.4
ownCloud version: 10.9.1
Updated from an older ownCloud or fresh install: always updated since a loooong time ago
Where did you install ownCloud from: tar.gz
    "system": {
        "loglevel": 2,
        "instanceid": "oceb871cbff2",
        "updatechecker": false,
        "knowledgebaseenabled": false,
        "trusted_domains": [
            "XXX"
        "appstoreenabled": true,
        "appstoreurl": "https:\/\/marketplace.owncloud.com\/",
        "datadirectory": "\/var\/www\/XXX\/htdocs\/owncloud\/data",
        "dbtype": "mysql",
        "version": "10.9.1.2",
        "dbname": "owncloud",
        "files_external_allow_create_new_local": "true",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "installed": true,
        "forcessl": true,
        "mail_smtpmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpauthtype": "LOGIN",
        "theme": "",
        "trashbin_retention_obligation": "180, auto",
        "overwrite.cli.url": "\/owncloud",
        "maintenance": false,
        "cache_path": "",
        "filelocking.enabled": true,
        "memcache.local": "\\OC\\Memcache\\Redis",
        "redis": {
            "host": "\/var\/run\/redis\/redis.sock",
            "port": 0,
            "timeout": 0,
            "dbindex": 0
        "apps_paths": [
                "path": "\/var\/www\/XXX\/htdocs\/owncloud\/apps",
                "url": "\/apps",
                "writable": true
        "htaccess.RewriteBase": "\/owncloud",
        "mail_smtpport": "587",
        "mail_smtpsecure": "tls",
        "singleuser": false,
        "allow_user_to_change_mail_address": ""
Enabled:
  - dav:
    - Version: 0.7.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/dav
  - encryption:
    - Version: 1.5.1
    - Path: /var/www/XXX/htdocs/owncloud/apps/encryption
  - federatedfilesharing:
    - Version: 0.5.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/federatedfilesharing
  - federation:
    - Version: 0.1.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/federation
  - files:
    - Version: 1.5.2
    - Path: /var/www/XXX/htdocs/owncloud/apps/files
  - files_external:
    - Version: 0.8.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_external
  - files_mediaviewer:
    - Version: 1.0.5
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_mediaviewer
  - files_pdfviewer:
    - Version: 1.0.1
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_pdfviewer
  - files_sharing:
    - Version: 0.14.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_sharing
  - files_versions:
    - Version: 1.3.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_versions
  - gallery:
    - Version: 16.1.2
    - Path: /var/www/XXX/htdocs/owncloud/apps/gallery
  - market:
    - Version: 0.6.2
    - Path: /var/www/XXX/htdocs/owncloud/apps/market
  - notifications:
    - Version: 0.5.4
    - Path: /var/www/XXX/htdocs/owncloud/apps/notifications
  - provisioning_api:
    - Version: 0.5.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/provisioning_api
  - systemtags:
    - Version: 0.3.0
    - Path: /var/www/XXX/htdocs/owncloud/apps/systemtags
  - updatenotification:
    - Version: 0.2.1
    - Path: /var/www/XXX/htdocs/owncloud/apps/updatenotification
Disabled:
  - calendar:
    - Path: /var/www/XXX/htdocs/owncloud/apps/calendar
  - comments:
    - Path: /var/www/XXX/htdocs/owncloud/apps/comments
  - configreport:
    - Path: /var/www/XXX/htdocs/owncloud/apps/configreport
  - contacts:
    - Path: /var/www/XXX/htdocs/owncloud/apps/contacts
  - external:
    - Path: /var/www/XXX/htdocs/owncloud/apps/external
  - files_texteditor:
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_texteditor
  - files_trashbin:
    - Path: /var/www/XXX/htdocs/owncloud/apps/files_trashbin
  - firstrunwizard:
    - Path: /var/www/XXX/htdocs/owncloud/apps/firstrunwizard
  - user_external:
    - Path: /var/www/XXX/htdocs/owncloud/apps/user_external
Are you using external storage, if yes which one: NO
Are you using encryption: yes
Are you using an external user-backend, if yes which one: NO
Any
Any
Nothing
That seems a broken header, so most likely ownCloud thinks the file isn’t encrypted and sends it without any change.
Is it possible to know when the file got uploaded?. Either the file was modified in the storages (which seems weird) or the file got uploaded with a very old ownCloud version and ownCloud broke compatibility at some point.
For the second case, the original ownCloud version is important in order to try to reproduce the problem.
You can also check the oc_filecache table to verify the target file is marked as encrypted there (“encrypted” column should be greater or equal to 1 if it’s encrypted)
If you have the original unencrypted file somewhere, the easiest solution would be to delete that file and reupload it
Makes sense…
I don’t have the original anymore…
The photo was taken on 12.12.2014 so… the initial owncloud version should be around then. Unfortunately, I don’t know when the compatibility broke. I just noticed now when trying to create a backup…
Looks like encrypted for it is 0.
you might want try to to set that “encrypted” value to 1 (only for the target file), but it’s a blind shot and it might break the file further.
First thing I did yesterday after you mentioned it.
/IMG_4180.JPG - Cannot multikey decrypt empty plain content
