Default login on Raspberry Pi with DietPi
  1. Install from DietPi on Raspberry Pi
  2. Attempt to login at http://ipaddress/Owncloud
I installed Owncloud following the instructions at How to set up a Raspberry Pi ownCloud server - The Pi which led me to expect that I would be able to create the admin account etc
I was greeted by a login page. I tried the logins already set up on the Raspberry Pi prior to installing Owncloud, no success
DietPi_RPi-ARMv8-Buster
LightHPPD
Current version from Owncloud via DietPi
fresh install
via the DietPi software installation page
From step 4:
The setup wizard will prompt you to create an admin account. Choose your username and password,
