Hello, I’m new and I need help.
Which file can I change the default setting on the public upload form to file drop only.
Regards.
Diogo.
Regards.
Diogo.
did you read the manual? It’s all there:
https://doc.owncloud.com/server/user_manual/files/public_link_shares.html
Thank you very much Cortho, I read the manual and the process described just let me choose the “drop file only” manually, I need this to be the default option.
Regards.
Diogo Souza.
Sorry for the misunderstanding. In this case I’d have a look at /core/js/sharedialoglinkshareview.js, this is where the dialog is created. You might want to create your own theme and override this file.
HTH
