Is there a way i can delete reshares on my files maybe direct on the DB (oc_share table)??
i have admin1 that share a folder with user2 and user2 reshared that file with user3. I want to be able to delete all shares so only admin1 can see the files. Note: i may or may not have the password of admin1.
As far as I can tell there is no way to look only for re shares in the database. It’s a share type 0, just like a normal user share.
You can reset your admins password, or set it to something you want. You can also create a new user with a new password and put him in the admin group, granting him admin privileges.
Here is the occ password reset command:
occ user:resetpassword --help
Description:
Resets the password of the named user.
Usage:
user:resetpassword [options] [--] <user>
Arguments:
user The user's name.
Options:
--password-from-env Read the password from the OC_PASS environment variable.
--send-email The email-id set while creating the user, will be used to send link for password reset. This option will also display the link sent to user.
--output-link The link to reset the password will be displayed.
Sorry if I didn’t make myself clear. I want to delete all shares, no matter who the share user is. Just found the reshare=true arguments from OCS api but that way I would need to iterate over every share
