Not really. You need to be able to run occ in order to manage it easily.
I would mount the webspace locally to run a command to delete all thumbnail folders.
But you still have all the thumbnails referenced in your ownCloud database. For that I would normally recommend to run a files:scan --repair however that’s not possible for you.
So you will have to go into the database and manually delete the entries in the oc_filecache table. Be very careful if you go down that route.
thanks a lot. after 10 years using 1&1 this are really good news.
now I installed putty and got connected.
please help me to understand the commands:
occ files:scan --all … what does it? delete the thumbnails?
occ upgrade … what does it? I’m not up do date with my installation (it is actually 10.0.10) - but every time I update I lost my installation (white screen and php errors) so I really don’t want to update the whole installation.
EDIT: the best think for me could be, that the thumbnails are not cached to my webspace when generated. it would last longer to load/view, but this is not a problem, because I use the webinterface rarely.
to foster all functionalities. Something like an app-shell… J
Now the issue with the thumbnails is new to me – and I (up-to-now) do not know, what specific command does help you to clean-up the respective directory, BUT I can recommend definitely to use the command an prepare your Installation and upgrade it to the current level
Eventually we can connect directly and setup a video-call, so I understand better your current situation. www.lj2.de
One command following this threat already explained the config.php addendum, so eventually by the end of the day the set of issues are already solved
