Deleted files on client still on web interface
I perfomed a fresh install with bitnami on amazon aws. Everything is working fine, except when I delete files with desktop app. If I delete the shared/unshared files with the desktop client the files still appearing on web interface. And when I try to delete them from web an error occurs saying that I can’t delete files.
I searched a lot and din’t find a similar problem. How can I solve this?
Another question, how can I disable the trash? I already set ‘trashbin_retention_obligation’ => ‘0’ and ‘versions_retention_obligation’ => ‘0’ and deleted files are being moved to trash.
P.s. deleting files from web works fine. The files are moved to trash and if i delete on trash files are permanently deleted.
I make one change. Now I’m using google-drive-ocamlfuse to mount google drive as the data folder. Everything works fine as expected. But the problem I mentioned earlier continues. If I deleted files on google drive web interface or desktop client the files still appearing on OwnCloud web interface.
Please fill out the shown template when creating a new thread. Up to now its not even known which oC version you’re running.
Dear all,
I face the following error message, and after spending days on Github and forums, I am stuck.
When trying to delete files from desktop clients from shared or unshared folders the files still appearing on web interface. Now I am using google drive mounted on my data folder. Upload and everything else works, but the deleted files has the same problem.
What I checked and did …
  • Delete files from web interface works
  • Upload and sync from web interface and desktop works fine
  • Uploads on shared folders are ok
  1. Upload a file to OwnCloud from web or desktop client.
  2. Delete file from desktop client.
  3. Open web interface, deleted files still appearing.
  4. Try to delete, open or download files get error.
Deleted files on desktop should delete it on web interface too.
Deleted files on desktop still appearing on web interface.
Operating system: Ubuntu 14.04.4 LTS Trusty
Web server: Apache/2.4.20
Database: Mysql 5.6.30
PHP Version: 5.6.21
ownCloud version (see ownCloud admin page): 9.0.4 (stable)
Updated from an older ownCloud or fresh install: Fresh Install.
OwnCloud log:
https://drive.google.com/open?id=0B_NAfcN3WZ72UHk1X1dZNVhBTEE
config.php:
<?php $CONFIG = array ( 'passwordsalt' => 'xxxx', 'secret' => 'xxx', 'trusted_domains' => array ( 0 => '127.0.0.1', 1 => 'ec2-52-67-30-72.sa-east-1.compute.amazonaws.com', 2 => 'profissional.saggin.com.br', 3 => 'scloud.saggin.com.br', ), 'datadirectory' => '/opt/bitnami/apps/owncloud/data/Saggin/FTP_OwnCloud', 'overwrite.cli.url' => 'http://localhost', 'dbtype' => 'mysql', 'version' => '9.0.4.1', 'dbname' => 'bitnami_owncloud', 'dbhost' => '127.0.0.1:/opt/bitnami/mysql/tmp/mysql.sock', 'dbtableprefix' => 'oc_', 'dbuser' => 'bn_owncloud', 'dbpassword' => 'xxx', 'logtimezone' => 'UTC', 'installed' => true, 'instanceid' => 'oclo5lyc1sag', 'theme' => 'saggin', 'trashbin_retention_obligation' => '0', 'versions_retention_obligation' => '0', 'openssl' => array ( 'config' => '/opt/bitnami/common/openssl/openssl.cnf', ), 'updater.secret' => 'xxx', 'loglevel' => 2, 'maintenance' => false, 'htaccess.RewriteBase' => '/', );
Another question:
How can I disable the trash?
Thanks all,
Best regards.
you somehow directly access owncloud via ip. In that case, you have to add the server ip (52.67.x.x) to the trusted_domains as well.
I now why I’m using this ip, it’s a AWS server config, I will try to add this and test if. I’ll come back to write if it solves the problem.
The problem still happening.
This is the new owncloud.log output.
owncloud.log
{"reqId":"eY4HxD0\/xifqwxtzSj2l","remoteAddr":"188.114.98.99","app":"PHP","message":"rename(\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files\/mapa-brasil.png,\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/mapa-brasil.png.d1469487739): Device or resource busy at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#249","level":3,"time":"2016-07-25T23:02:23+00:00","method":"DELETE","url":"\/remote.php\/webdav\/mapa-brasil.png","user":"mateussaggin"}
{"reqId":"3h+VPeT+xY2VzEZxzcha","remoteAddr":"188.114.99.106","app":"PHP","message":"rename(\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files\/SAGGIN FOTOGRAFIAS.psd,\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/SAGGIN FOTOGRAFIAS.psd.d1469487739): Device or resource busy at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#249","level":3,"time":"2016-07-25T23:02:27+00:00","method":"DELETE","url":"\/remote.php\/webdav\/SAGGIN%20FOTOGRAFIAS.psd","user":"mateussaggin"}
{"reqId":"2uZpeByaDQEV2fqRYOTN","remoteAddr":"188.114.98.105","app":"PHP","message":"rename(\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files\/machosa-logo.png,\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/machosa-logo.png.d1469487739): No such file or directory at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#249","level":3,"time":"2016-07-25T23:02:37+00:00","method":"DELETE","url":"\/remote.php\/webdav\/machosa-logo.png","user":"mateussaggin"}
{"reqId":"eY4HxD0\/xifqwxtzSj2l","remoteAddr":"188.114.98.99","app":"PHP","message":"filemtime(): stat failed for \/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/mapa-brasil.png.d1469487739 at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#159","level":3,"time":"2016-07-25T23:02:41+00:00","method":"DELETE","url":"\/remote.php\/webdav\/mapa-brasil.png","user":"mateussaggin"}
{"reqId":"3h+VPeT+xY2VzEZxzcha","remoteAddr":"188.114.99.106","app":"PHP","message":"filemtime(): stat failed for \/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/SAGGIN FOTOGRAFIAS.psd.d1469487739 at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#159","level":3,"time":"2016-07-25T23:02:43+00:00","method":"DELETE","url":"\/remote.php\/webdav\/SAGGIN%20FOTOGRAFIAS.psd","user":"mateussaggin"}
{"reqId":"2uZpeByaDQEV2fqRYOTN","remoteAddr":"188.114.98.105","app":"PHP","message":"filemtime(): stat failed for \/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files_trashbin\/files\/machosa-logo.png.d1469487739 at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#159","level":3,"time":"2016-07-25T23:02:46+00:00","method":"DELETE","url":"\/remote.php\/webdav\/machosa-logo.png","user":"mateussaggin"}
{"reqId":"sfXRVsVqOhBG1WkQNWuu","remoteAddr":"188.114.98.106","app":"PHP","message":"fopen(\/opt\/bitnami\/apps\/owncloud\/data\/Saggin\/FTP_OwnCloud\/mateussaggin\/files\/943774_983458468404127_3803638278002991570_n.jpg): failed to open stream: No such file or directory at \/opt\/bitnami\/apps\/owncloud\/htdocs\/lib\/private\/files\/storage\/local.php#261","level":3,"time":"2016-07-25T20:27:35-03:00","method":"GET","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.jpg","user":"mateussaggin"}
{"reqId":"sfXRVsVqOhBG1WkQNWuu","remoteAddr":"188.114.98.106","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 503 Could not open file\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\ServiceUnavailable\",\"Code\":0,\"Trace\":\"#0 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(83): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->get()\\n#1 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpGet(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#3 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:GET', Array)\\n#4 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#6 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/remote.php(138): require_once('\\\/opt\\\/bitnami\\\/ap...')\\n#7 {main}\",\"File\":\"\\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":306,\"User\":\"mateussaggin\"}","level":4,"time":"2016-07-25T20:27:37-03:00","method":"GET","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.jpg","user":"mateussaggin"}
{"reqId":"sfXRVsVqOhBG1WkQNWuu","remoteAddr":"188.114.98.106","app":"PHP","message":"Cannot modify header information - headers already sent by (output started at \/opt\/bitnami\/apps\/owncloud\/htdocs\/3rdparty\/sabre\/http\/lib\/Sapi.php:83) at \/opt\/bitnami\/apps\/owncloud\/htdocs\/3rdparty\/sabre\/http\/lib\/Sapi.php#58","level":3,"time":"2016-07-25T20:27:40-03:00","method":"GET","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.jpg","user":"mateussaggin"}
{"reqId":"sfXRVsVqOhBG1WkQNWuu","remoteAddr":"188.114.98.106","app":"PHP","message":"Cannot modify header information - headers already sent by (output started at \/opt\/bitnami\/apps\/owncloud\/htdocs\/3rdparty\/sabre\/http\/lib\/Sapi.php:83) at \/opt\/bitnami\/apps\/owncloud\/htdocs\/3rdparty\/sabre\/http\/lib\/Sapi.php#63","level":3,"time":"2016-07-25T20:27:42-03:00","method":"GET","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.jpg","user":"mateussaggin"}
And this is the apache log:
Apache log
[Mon Jul 25 22:37:45.784843 2016] [ssl:warn] [pid 3345:tid 140505020319552] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 25 22:37:45.834552 2016] [ssl:warn] [pid 3346:tid 140505020319552] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 25 22:37:45.834651 2016] [lbmethod_heartbeat:notice] [pid 3346:tid 140505020319552] AH02282: No slotmem from mod_heartmonitor
[Mon Jul 25 22:37:45.850783 2016] [mpm_event:notice] [pid 3346:tid 140505020319552] AH00489: Apache/2.4.20 (Unix) OpenSSL/1.0.2h configured -- resuming normal operations
[Mon Jul 25 22:37:45.850824 2016] [core:notice] [pid 3346:tid 140505020319552] AH00094: Command line: '/opt/bitnami/apache2/bin/httpd.bin -f /opt/bitnami/apache2/conf/httpd.conf'
[Mon Jul 25 22:43:21.904310 2016] [core:error] [pid 3363:tid 140504528242432] (13)Permission denied: [client 188.114.99.106:62435] AH00035: access to / denied (filesystem path '/opt/bitnami/apps/owncloud/htdocs') because search permissions are missing on a component of the path
[Mon Jul 25 22:43:25.174134 2016] [core:error] [pid 3364:tid 140504427529984] (13)Permission denied: [client 188.114.99.106:15149] AH00035: access to / denied (filesystem path '/opt/bitnami/apps/owncloud/htdocs') because search permissions are missing on a component of the path
[Mon Jul 25 23:08:52.086397 2016] [autoindex:error] [pid 3364:tid 140504427529984] [client 188.114.99.106:64846] AH01276: Cannot serve directory /opt/bitnami/apps/owncloud/htdocs/core/doc/user/_static/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://scloud.saggin.com.br/core/doc/user/index.html
[Mon Jul 25 23:21:35.034826 2016] [mpm_event:notice] [pid 3346:tid 140505020319552] AH00491: caught SIGTERM, shutting down
[Mon Jul 25 23:22:50.596147 2016] [ssl:warn] [pid 1510:tid 140310776543040] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 25 23:22:50.642242 2016] [ssl:warn] [pid 1511:tid 140310776543040] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 25 23:22:50.642357 2016] [lbmethod_heartbeat:notice] [pid 1511:tid 140310776543040] AH02282: No slotmem from mod_heartmonitor
[Mon Jul 25 23:22:50.658663 2016] [mpm_event:notice] [pid 1511:tid 140310776543040] AH00489: Apache/2.4.20 (Unix) OpenSSL/1.0.2h configured -- resuming normal operations
[Mon Jul 25 23:22:50.658708 2016] [core:notice] [pid 1511:tid 140310776543040] AH00094: Command line: '/opt/bitnami/apache2/bin/httpd.bin -f /opt/bitnami/apache2/conf/httpd.conf'
EDIT:
owncloud.log with level 0
{"reqId":"7xfuXh6+ekxWUE1\/nD+f","remoteAddr":"188.114.98.106","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 403 Forbidden\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\Forbidden\",\"Code\":0,\"Trace\":\"#0 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('943774_98345846...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/remote.php(138): require_once('\\\/opt\\\/bitnami\\\/ap...')\\n#8 {main}\",\"File\":\"\\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":335,\"User\":\"mateussaggin\"}","level":0,"time":"2016-07-25T20:44:12-03:00","method":"DELETE","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.jpg","user":"mateussaggin"}
{"reqId":"oYA4cg+P\/Og\/Tst8Wyik","remoteAddr":"188.114.97.96","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 403 Forbidden\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\Forbidden\",\"Code\":0,\"Trace\":\"#0 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('943774_98345846...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/remote.php(138): require_once('\\\/opt\\\/bitnami\\\/ap...')\\n#8 {main}\",\"File\":\"\\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":335,\"User\":\"mateussaggin\"}","level":0,"time":"2016-07-25T20:44:12-03:00","method":"DELETE","url":"\/remote.php\/webdav\/943774_983458468404127_3803638278002991570_n.png","user":"mateussaggin"}
{"reqId":"SSlpXM3wY\/TxyrLPXyp3","remoteAddr":"188.114.97.66","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 403 Forbidden\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\Forbidden\",\"Code\":0,\"Trace\":\"#0 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('capa-ensaio.jpg')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/remote.php(138): require_once('\\\/opt\\\/bitnami\\\/ap...')\\n#8 {main}\",\"File\":\"\\\/opt\\\/bitnami\\\/apps\\\/owncloud\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":335,\"User\":\"mateussaggin\"}","level":0,"time":"2016-07-25T20:44:13-03:00","method":"DELETE","url":"\/remote.php\/webdav\/capa-ensaio.jpg","user":"mateussaggin"}
I clear the log and this outputs was generated when trying to delete the files from web interface. This files that I tried to delete was already deleted from desktop client.
Seems you have some issues with the filesystem / operating system itself:
Maybe throwing this message into your favorite search engine gives you some additional infos.
It also seems that there is something reall strange configured at your install. You have a datadir of:
configured but the logfiles contains stuff like:
/opt/bitnami/apps/owncloud/data/Saggin/FTP_OwnCloud/mateussaggin/filename
As your user is “mateussaggin” you should get entries like:
/opt/bitnami/apps/owncloud/data/Saggin/mateussaggin/filename
Questions that remain:
  • Where is FTP_OWNCLOUD coming from?
  • Are you modifying stuff in the datadir manually on the server?
  • Are you using external storages?
  • Have you moved the datadir after the installation?
Sorry for the delay. Answering your questions.
  • FTP_OWNCLOUD are on Google Drive.
  • I manually change the config.php, skeleton and theme files.
  • I am using Google Drive as a External Storage and Primary Storage
  • I moved the datadir after install.
Now I’m installing a fresh install of owncloud. I will use Bitnami Owncloud on Amazon EC2. And use Amazon EBS as Primary Storage. I will try it and I will post if everything is working. Thanks.
