Thank you for the follow-up:
I just did a full update of windows and now I am getting a file lock error as below. I can also confirm that my other users are not experiencing this issue. I have full admin rights as does one of my coworkers and it is working properly for him.
The error message from the server is as follows:
{“reqId”:“71c6d739-409a-4378-b0fb-9ed7c3f2e290”,“level”:4,“time”:“2021-02-10T16:28:20+00:00”,“remoteAddr”:“192.168.1.254”,“user”:“1B3C19E4-FE8D-49B2-B845-3F9F9C8993F4”,“app”:“webdav”,“method”:“DELETE”,“url”:"/remote.php/dav/files/1B3C19E4-FE8D-49B2-B845-3F9F9C8993F4/M%20Drive/Admin/MAB/TestEE",“message”:“Exception: HTTP/1.1 423 “M Drive/Admin/MAB/TestEE” is locked: {“Exception”:“OCA\\DAV\\Connector\\Sabre\\Exception\\FileLocked”,“Message”:”\“M Drive\/Admin\/MAB\/TestEE\” is locked",“Code”:0,“Trace”:"#0 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Tree.php(181): OCA\\DAV\\Connector\\Sabre\\Directory->delete()\n#1 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(281): Sabre\\DAV\\Tree->delete()\n#2 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/event\/lib\/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpDelete()\n#3 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(470): Sabre\\DAV\\Server->emit()\n#4 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(251): Sabre\\DAV\\Server->invokeMethod()\n#5 \/var\/www\/html\/owncloud\/apps\/dav\/lib\/Server.php(329): Sabre\\DAV\\Server->start()\n#6 \/var\/www\/html\/owncloud\/apps\/dav\/appinfo\/v2\/remote.php(31): OCA\\DAV\\Server->exec()\n#7 \/var\/www\/html\/owncloud\/remote.php(165): require_once(’\/var\/www\/html\/o…’)\n#8
