Running Owncloud server 9.1 on Mageia X86_64 system Please suggest appropriate client for installation on other Mageia systems including my laptop.
Graeme
the client is build using the openSUSE Open Build Service which is not supporting Mageia as seen here:
https://en.opensuse.org/openSUSE:Build_Service_supported_build_targets
Please request support for Mageia from the openSUSE Open Build Service people. Afterwards the ownCloud sync client can be build for this Distribution (if its requested by you at GitHub · Where software is built)
The latest ownCloud client 2.2.4 seems to be packaged by Mageia downstream, according to http://madb.mageia.org/package/show/name/owncloud-client/arch/x86_64
That is perfect, you should install from there.
Many thanks. I now have it.
Graeme
