work sync
the sync dont work because the client “Could not read system exclude file”
i try referr the 18525 topic but i cant found the sys-exclude.lst in my system
- Built with KDE Craft method
- Add the IP of my owncloud server
- wait sync
Operating system: Windows 10
Web server: -
Database: -
PHP version: -
ownCloud version: -
Storage backend (external storage): -
Client version: 2.7
Operating system: windows 10
OS language: en-us
Qt version used by client package (Linux only, see also Settings dialog): 5.1.2
Client package (From ownCloud or distro) (Linux only): -
Installation path of client: c:\craftroot\bin
08-19 10:49:38:430 [ info gui.application ]: “################## ownCloud locale:[en_US] ui_lang: version:[2.7.0git] os:[Windows 10 (10.0)]”
08-19 10:49:38:430 [ info gui.application ]: Using “en_US” translation
08-19 10:49:38:430 [ info gui.application ]: Adding extra plugin search path: “C:/CraftRoot/lib/ownCloud/plugins”
08-19 10:49:38:430 [ info gui.application ]: VFS suffix plugin is available
08-19 10:49:38:430 [ info gui.socketapi ]: server started, listening at “\\.\pipe\ownCloud-Reberth”
08-19 10:49:38:430 [ info gui.folder.manager ]: setting remote poll timer interval to 30000 msec
08-19 10:49:38:445 [ warning default ]: QIODevice::read (QFile, “C:\Users\Reberth\AppData\Local\ownCloud\cookies0.db”): device not open
08-19 10:49:38:854 [ info gui.application ]: Tray menu workarounds: noabouttoshow: false fakedoubleclick: false showhide: false manualvisibility: false
08-19 10:49:38:860 [ info gui.folder.manager ]: Setup folders from settings file
08-19 10:49:38:861 [ info sync.database ]: Detected filesystem “NTFS” for “C:/Users/Reberth/ownCloud3/.sync_5040ef8273e2.db”
08-19 10:49:38:861 [ info sync.configfile ]: Adding system ignore list to csync: “C:/CraftRoot/bin/sync-exclude.lst”
08-19 10:49:38:862 [ warning gui.folder ]: Could not read system exclude file
08-19 10:49:38:864 [ info sync.database ]: sqlite3 version “3.27.2”
08-19 10:49:38:864 [ info sync.database ]: sqlite3 locking_mode= “exclusive”
08-19 10:49:38:864 [ info sync.database ]: sqlite3 journal_mode= “wal”
08-19 10:49:38:864 [ info sync.database ]: sqlite3 synchronous= “NORMAL”
08-19 10:49:38:897 [ info gui.folder.manager ]: Adding folder to Folder Map OCC::Folder(0x22d6a5f2f10) “1”
08-19 10:49:38:898 [ info gui.folder.manager ]: Schedule folder “1” to sync!
08-19 10:49:38:898 [ info gui.folder.manager ]: Folder is not ready to sync, not scheduled!
08-19 10:49:38:900 [ info gui.application ]: Sync state changed for folder “https://18.231.55.195/remote.php/webdav/” : “Not yet Started”
08-19 10:49:38:900 [ info sync.clientproxy ]: Set proxy configuration to use system configuration
08-19 10:49:38:914 [ info gui.account.state ]: Fetched credentials for “https://18.231.55.195” attempting to connect
08-19 10:49:38:921 [ info sync.connectionvalidator ]: No system proxy set by OS
08-19 10:49:38:921 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/status.php” has X-Request-ID “91290aba-c276-475b-8e31-6240714aacea”
08-19 10:49:38:921 [ info sync.networkjob ]: OCC::CheckServerJob created for “https://18.231.55.195” + “status.php” “OCC::ConnectionValidator”
08-19 10:49:38:960 [ info gui.account.manager ]: Saving account “https://18.231.55.195”
08-19 10:49:38:960 [ info gui.account.manager ]: Saving 1 unknown certs.
08-19 10:49:38:960 [ info gui.account.manager ]: Saving cookies. “C:/Users/Reberth/AppData/Local/ownCloud/cookies0.db”
08-19 10:49:38:960 [ warning default ]: QIODevice::write (QFile, “C:\Users\Reberth\AppData\Local\ownCloud\cookies0.db”): device not open
08-19 10:49:39:056 [ info gui.account.manager ]: Saved account settings, status: QSettings::NoError
08-19 10:49:39:056 [ info sync.account ]: “SSL-Errors happened for url "https://18.231.55.195/status.php\” \tError in QSslCertificate("3", "6f:82:d9:8b:42:78:fc:39:f7:35:f2:b0:ff:79:01:11:8d:c8:eb:4d", "U5yesKnMKjF5YmlnO/gr5Q==", "RESULT TECNOLOGIA", "RESULT TECNOLOGIA", QMap(), QDateTime(2019-08-13 14:11:02.000 UTC Qt::UTC), QDateTime(2020-08-12 14:11:02.000 UTC Qt::UTC)) : "The host name did not match any of the valid hosts for this certificate" ( "The host name did not match any of the valid hosts for this certificate" ) \n \tError in QSslCertificate("3", "6f:82:d9:8b:42:78:fc:39:f7:35:f2:b0:ff:79:01:11:8d:c8:eb:4d", "U5yesKnMKjF5YmlnO/gr5Q==", "RESULT TECNOLOGIA", "RESULT TECNOLOGIA", QMap(), QDateTime(2019-08-13 14:11:02.000 UTC Qt::UTC), QDateTime(2020-08-12 14:11:02.000 UTC Qt::UTC)) : "The certificate is self-signed, and untrusted" ( "The certificate is self-signed, and untrusted" ) \n " Certs are known and trusted! This is not an actual error.
08-19 10:49:39:080 [ warning sync.networkjob.checkserver ]: No SSL session identifier / session ticket is used, this might impact sync performance negatively.
08-19 10:49:39:080 [ info sync.networkjob.checkserver ]: status.php returns: QJsonDocument({“edition”:“Community”,“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“productname”:“Result - Tecnologia Cloud Storage”,“version”:“10.2.1.4”,“versionstring”:“10.2.1”}) QNetworkReply::NoError Reply: QNetworkReplyHttpImpl(0x22d6a6184e0)
08-19 10:49:39:080 [ info sync.connectionvalidator ]: ** Application: ownCloud found: QUrl(“https://18.231.55.195”) with version “10.2.1” ( “10.2.1.4-Result - Tecnologia Cloud Storage” )
08-19 10:49:39:080 [ info sync.connectionvalidator ]: QUrl(“https://18.231.55.195”) has server version “10.2.1.4-Result - Tecnologia Cloud Storage”
08-19 10:49:39:080 [ info sync.accessmanager ]: 6 “PROPFIND” “https://18.231.55.195/remote.php/webdav/” has X-Request-ID “ce4f94f9-60c8-4c03-8f40-2f0f9ec22d54”
08-19 10:49:39:081 [ info sync.networkjob ]: OCC::PropfindJob created for “https://18.231.55.195” + “/” “OCC::ConnectionValidator”
08-19 10:49:39:193 [ info sync.networkjob.propfind ]: PROPFIND of QUrl(“https://18.231.55.195/remote.php/webdav/”) FINISHED WITH STATUS “OK”
08-19 10:49:39:193 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/ocs/v1.php/cloud/capabilities?format=json” has X-Request-ID “260db61b-6d8d-4a62-bd50-d7546f0a137a”
08-19 10:49:39:194 [ info sync.networkjob ]: OCC::JsonApiJob created for “https://18.231.55.195” + “ocs/v1.php/cloud/capabilities” “OCC::ConnectionValidator”
08-19 10:49:39:194 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/ocs/v1.php/config?format=json” has X-Request-ID “85e05fc2-6922-4e6e-ad31-41e3c1458138”
08-19 10:49:39:195 [ info sync.networkjob ]: OCC::JsonApiJob created for “https://18.231.55.195” + “ocs/v1.php/config” “”
08-19 10:49:39:212 [ info gui.account.manager ]: Saving account “https://18.231.55.195”
08-19 10:49:39:212 [ info gui.account.manager ]: Saving 1 unknown certs.
08-19 10:49:39:213 [ info gui.account.manager ]: Saving cookies. “C:/Users/Reberth/AppData/Local/ownCloud/cookies0.db”
08-19 10:49:39:213 [ warning default ]: QIODevice::write (QFile, “C:\Users\Reberth\AppData\Local\ownCloud\cookies0.db”): device not open
08-19 10:49:39:261 [ info gui.account.manager ]: Saved account settings, status: QSettings::NoError
08-19 10:49:39:261 [ info sync.account ]: “SSL-Errors happened for url "https://18.231.55.195/ocs/v1.php/config?format=json\” \tError in QSslCertificate("3", "6f:82:d9:8b:42:78:fc:39:f7:35:f2:b0:ff:79:01:11:8d:c8:eb:4d", "U5yesKnMKjF5YmlnO/gr5Q==", "RESULT TECNOLOGIA", "RESULT TECNOLOGIA", QMap(), QDateTime(2019-08-13 14:11:02.000 UTC Qt::UTC), QDateTime(2020-08-12 14:11:02.000 UTC Qt::UTC)) : "The host name did not match any of the valid hosts for this certificate" ( "The host name did not match any of the valid hosts for this certificate" ) \n " Certs are known and trusted! This is not an actual error.
08-19 10:49:40:198 [ info sync.networkjob.jsonapi ]: JsonApiJob of QUrl(“https://18.231.55.195/ocs/v1.php/cloud/capabilities?format=json”) FINISHED WITH STATUS “OK”
08-19 10:49:40:198 [ info sync.connectionvalidator ]: Server capabilities QJsonObject({“checksums”:{“preferredUploadType”:“SHA1”,“supportedTypes”:[“SHA1”]},“core”:{“pollinterval”:60,“status”:{“edition”:“Community”,“hostname”:“ip-172-31-4-132”,“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“productname”:“Result - Tecnologia Cloud Storage”,“version”:“10.2.1.4”,“versionstring”:“10.2.1”},“webdav-root”:“remote.php/webdav”},“dav”:{“chunking”:“1.0”,“reports”:[“search-files”]},“files”:{“bigfilechunking”:true,“blacklisted_files”:[“.htaccess”],“privateLinks”:true,“privateLinksDetailsParam”:true,“undelete”:true,“versioning”:true},“files_sharing”:{“api_enabled”:true,“auto_accept_share”:true,“can_share”:true,“default_permissions”:31,“federation”:{“incoming”:true,“outgoing”:true},“group_sharing”:false,“public”:{“defaultPublicLinkShareName”:“Linque público”,“enabled”:true,“expire_date”:{“enabled”:false},“multiple”:true,“password”:{“enforced”:false,“enforced_for”:{“read_only”:false,“read_write”:false,“upload_only”:false}},“send_mail”:false,“social_share”:true,“supports_upload_only”:true,“upload”:true},“resharing”:true,“search_min_length”:2,“share_with_group_members_only”:true,“share_with_membership_groups_only”:true,“user”:{“send_mail”:false},“user_enumeration”:{“enabled”:false}},“notifications”:{“ocs-endpoints”:[“list”,“get”,“delete”]}})
08-19 10:49:40:198 [ info sync.connectionvalidator ]: QUrl(“https://18.231.55.195”) has server version “10.2.1.4”
08-19 10:49:40:198 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/ocs/v1.php/cloud/user?format=json” has X-Request-ID “eaa15094-ad6b-403b-a1fd-2508f243e53d”
08-19 10:49:40:198 [ info sync.networkjob ]: OCC::JsonApiJob created for “https://18.231.55.195” + “ocs/v1.php/cloud/user” “OCC::ConnectionValidator”
08-19 10:49:40:214 [ info sync.networkjob.jsonapi ]: JsonApiJob of QUrl(“https://18.231.55.195/ocs/v1.php/config?format=json”) FINISHED WITH STATUS “OK”
08-19 10:49:40:214 [ info sync.connectionvalidator ]: Determined user-visible host to be “18.231.55.195”
08-19 10:49:40:245 [ info sync.networkjob.jsonapi ]: JsonApiJob of QUrl(“https://18.231.55.195/ocs/v1.php/cloud/user?format=json”) FINISHED WITH STATUS “OK”
08-19 10:49:40:245 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/remote.php/dav/avatars/admin/128.png” has X-Request-ID “ff161190-d105-4f82-9ca6-13e1124a2843”
08-19 10:49:40:245 [ info sync.networkjob ]: OCC::AvatarJob created for “https://18.231.55.195” + “” “OCC::ConnectionValidator”
08-19 10:49:40:292 [ warning sync.networkjob ]: QNetworkReply::ContentNotFoundError “Server replied "404 Not Found" to "GET https://18.231.55.195/remote.php/dav/avatars/admin/128.png\”" QVariant(int, 404)
08-19 10:49:40:292 [ info gui.account.state ]: AccountState connection status change: OCC::ConnectionValidator::Undefined → OCC::ConnectionValidator::Connected
08-19 10:49:40:292 [ info gui.account.state ]: AccountState state change: “Disconnected” → “Connected”
08-19 10:49:40:292 [ info gui.activity ]: Start fetching activities for “admin@18.231.55.195”
08-19 10:49:40:292 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/ocs/v1.php/cloud/activity?page=0&pagesize=100&format=json” has X-Request-ID “d1e0630d-5cc1-4a0a-ac7d-4f5330bff7b6”
08-19 10:49:40:292 [ info sync.networkjob ]: OCC::JsonApiJob created for “https://18.231.55.195” + “ocs/v1.php/cloud/activity” “OCC::ActivityListModel”
08-19 10:49:40:292 [ info sync.accessmanager ]: 2 “” “https://18.231.55.195/ocs/v2.php/apps/notifications/api/v1/notifications?format=json” has X-Request-ID “9314b90a-b29e-4394-bafe-05dcfd49d187”
08-19 10:49:40:292 [ info sync.networkjob ]: OCC::JsonApiJob created for “https://18.231.55.195” + “ocs/v2.php/apps/notifications/api/v1/notifications” “OCC::ServerNotificationHandler”
08-19 10:49:40:308 [ info gui.folder.manager ]: Account “admin@18.231.55.195” connected, scheduling its folders
08-19 10:49:40:308 [ info gui.folder.manager ]: Schedule folder “1” to sync!
08-19 10:49:40:308 [ info gui.application ]: Sync state changed for folder “https://18.231.55.195/remote.php/dav/files/admin/” : “Not yet Started”
08-19 10:49:40:308 [ info gui.folder.manager ]: Starting the next scheduled sync in 0 seconds
08-19 10:49:40:339 [ info sync.networkjob.jsonapi ]: JsonApiJob of QUrl(“https://18.231.55.195/ocs/v1.php/cloud/activity?page=0&pagesize=100&format=json”) FINISHED WITH STATUS “OK”
08-19 10:49:40:355 [ info sync.networkjob.jsonapi ]: JsonApiJob of QUrl(“https://18.231.55.195/ocs/v2.php/apps/notifications/api/v1/notifications?format=json”) FINISHED WITH STATUS “OK”
08-19 10:49:40:417 [ info gui.application ]: Sync state changed for folder “https://18.231.55.195/remote.php/dav/files/admin/” : “SyncPrepare”
08-19 10:49:40:417 [ info gui.folder ]: *** Start syncing “https://18.231.55.195/remote.php/dav/files/admin/” - ownCloud client version 2.7.0git
08-19 10:49:40:433 [ info gui.folder ]: Client version 2.7.0git Qt 5.13.0 SSL OpenSSL 1.1.1 11 Sep 2018
08-19 10:49:40:433 [ warning gui.folder ]: SyncEngine finished with ERROR
08-19 10:49:40:433 [ info gui.folder ]: Folder sync result: 2
08-19 10:49:40:433 [ info gui.folder ]: the last 1 syncs failed
08-19 10:49:40:448 [ info gui.application ]: Sync state changed for folder “https://18.231.55.195/remote.php/dav/files/admin/” : “Error”
08-19 10:49:40:649 [ info gui.folder.manager ]: <========== Sync finished for folder [ownCloud3] of account [admin@18.231.55.195] with remote [https://18.231.55.195/remote.php/dav/files/admin/]
08-19 10:49:41:931 [ info gui.updater ]: Checking for available update
08-19 10:49:41:931 [ info sync.accessmanager ]: 2 “” “https://updates.owncloud.com/client/?version=2.7.0.0&platform=win32&oem=ownCloud&versionsuffix=git&msi=true” has X-Request-ID “ed5bbf61-9856-4efd-bea9-3633f5f373b4”
08-19 10:49:42:807 [ info gui.updater ]: No version information available at the moment
Web server error log: -
Server logfile: ownCloud log (data/owncloud.log): -
