Desktop Synchronization Client crashes on Mac High Sierra on start
  1. Upgrade to High Sierra
  2. Start owncloud via applications/owncloud
  3. Upgrade (and or remove existing owncload and replace with 2.3.4 or 2.4 (beta)
Owncloud desktop app opens and runs and is visible in taskbar
Owncloud crashes immediately with error: “Sorry! Owncloud crashed please tell us about it!..”
mac os 10.13.1
na
na
na
2.3.4 or 2.4
either
https://download.owncloud.com/desktop/stable/ownCloud-2.3.4.8537.pkg
Shouldn’t a crash of a software be reported to a bugtracker?
Desktop Synchronization Client crashes on Mac High Sierra on start · Issue #6191 · owncloud/client · GitHub
