Hey everyone,
I am stuck with the next thing. I have enabled virtual files on my laptop. But it is saying that it does not have the rights to sync somehow (I did not change anything). When I look at my other computer it syncing without a problem. So I think it is my laptop (a Windows problem).
It will sync the file to the server
It will give an directory not accessible on client, permission denied owncloud
error
- Started computer
- Load Owncloud desktop client
Ubuntu 18.04
Apache 2
MySql
PHP 7.2
ownCloud version:
10.3.1
HDD DISK (partition on own server)
Client version:
Version 2.6.0 (build 12644)
Win 10
OS language:
Dutch
Installation path of client:
C:\Program Files (x86)\ownCloud
logs.
- Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile )
12-30 13:36:25:823 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:27:810 [ info gui.socketapi ]: New connection QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "REGISTER_PATH:C:\\Users\\xxx\\ownCloud" to QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Received SocketAPI message <-- "GET_STRINGS:CONTEXT_MENU_TITLE" from QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "GET_STRINGS:BEGIN" to QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "STRING:CONTEXT_MENU_TITLE:ownCloud" to QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "GET_STRINGS:END" to QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Received SocketAPI message <-- "GET_MENU_ITEMS:C:\\Users\\xxx\\AppData\\Local\\Temp\\ownCloud-logdir\\20191230_1336_owncloud.log.0" from QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "GET_MENU_ITEMS:BEGIN" to QLocalSocket(0x760f888)
12-30 13:36:27:811 [ info gui.socketapi ]: Sending SocketAPI message --> "GET_MENU_ITEMS:END" to QLocalSocket(0x760f888)
12-30 13:36:27:825 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:27:862 [ info gui.socketapi ]: Lost connection QLocalSocket(0x760f888)
12-30 13:36:29:826 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:30:620 [ debug gui.account.state ] [ OCC::AccountState::checkConnectivity ]: "daan@box.user.nl" The last ETag check succeeded within the last 30 secs. No connection check needed!
12-30 13:36:31:828 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:33:830 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:35:832 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:37:748 [ info gui.folder ]: Trying to check "https://box.user.nl/remote.php/dav/files/daan/" for changes via ETag check. (time since last sync: 108 s)
12-30 13:36:37:748 [ debug gui.folder.manager ] [ OCC::FolderMan::slotRunOneEtagJob ]: Scheduling "https://box.user.nl/remote.php/dav/files/daan/" to check remote ETag
12-30 13:36:37:748 [ info sync.accessmanager ]: 6 "PROPFIND" "https://box.user.nl/remote.php/dav/files/daan/" has X-Request-ID "abf72bb7-ddd6-4444-bebc-e59685e48143"
12-30 13:36:37:749 [ debug sync.cookiejar ] [ OCC::CookieJar::cookiesForUrl ]: QUrl("https://box.user.nl/remote.php/dav/files/daan/") requests: (QNetworkCookie("oc_sessionPassphrase=Uza4KLF%2BenTRpgfyQbzkzr7bG2y4BS42c96TBMXQij8gX%2Ba85hdM2vFHZHI1xjI%2FanZZRwHsND%2FG7tJrlDRLIe78TrHMRT%2BKv3joDO1rGIRYLekVKMlnBbPiXWuuYSIi; secure; HttpOnly; domain=box.user.nl; path=/"), QNetworkCookie("oc0se6n0vcqb=m2clco10srtqr4p50tdbgacfn6; secure; HttpOnly; domain=box.user.nl; path=/"))
12-30 13:36:37:749 [ info sync.networkjob ]: OCC::RequestEtagJob created for "https://box.user.nl" + "/" "OCC::Folder"
12-30 13:36:37:833 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:38:043 [ info sync.networkjob.etag ]: Request Etag of QUrl("https://box.user.nl/remote.php/dav/files/daan/") FINISHED WITH STATUS "OK"
12-30 13:36:38:051 [ debug sync.networkjob ] [ OCC::AbstractNetworkJob::slotFinished ]: Network job OCC::RequestEtagJob finished for "/"
12-30 13:36:39:836 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:40:876 [ info sync.accessmanager ]: 6 "PROPFIND" "https://box.user.nl/remote.php/dav/files/daan/" has X-Request-ID "52ea8619-a309-4409-8f69-17b2a13a84f3"
12-30 13:36:40:877 [ debug sync.cookiejar ] [ OCC::CookieJar::cookiesForUrl ]: QUrl("https://box.user.nl/remote.php/dav/files/daan/") requests: (QNetworkCookie("oc_sessionPassphrase=Uza4KLF%2BenTRpgfyQbzkzr7bG2y4BS42c96TBMXQij8gX%2Ba85hdM2vFHZHI1xjI%2FanZZRwHsND%2FG7tJrlDRLIe78TrHMRT%2BKv3joDO1rGIRYLekVKMlnBbPiXWuuYSIi; secure; HttpOnly; domain=box.user.nl; path=/"), QNetworkCookie("oc0se6n0vcqb=m2clco10srtqr4p50tdbgacfn6; secure; HttpOnly; domain=box.user.nl; path=/"))
12-30 13:36:40:877 [ info sync.networkjob ]: OCC::PropfindJob created for "https://box.user.nl" + "/" "OCC::QuotaInfo"
12-30 13:36:40:945 [ info sync.networkjob.propfind ]: PROPFIND of QUrl("https://box.user.nl/remote.php/dav/files/daan/") FINISHED WITH STATUS "OK"
12-30 13:36:40:945 [ debug sync.networkjob ] [ OCC::AbstractNetworkJob::slotFinished ]: Network job OCC::PropfindJob finished for "/"
12-30 13:36:41:837 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:43:839 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:45:841 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:47:843 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:49:845 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:51:846 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:53:848 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:55:848 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:57:851 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:36:59:853 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:01:854 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:03:856 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:05:857 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:07:746 [ info gui.folder ]: Trying to check "https://box.user.nl/remote.php/dav/files/daan/" for changes via ETag check. (time since last sync: 138 s)
12-30 13:37:07:747 [ debug gui.folder.manager ] [ OCC::FolderMan::slotRunOneEtagJob ]: Scheduling "https://box.user.nl/remote.php/dav/files/daan/" to check remote ETag
12-30 13:37:07:747 [ info sync.accessmanager ]: 6 "PROPFIND" "https://box.user.nl/remote.php/dav/files/daan/" has X-Request-ID "fcc390d0-463f-4711-bf76-d236c980ad4d"
12-30 13:37:07:747 [ debug sync.cookiejar ] [ OCC::CookieJar::cookiesForUrl ]: QUrl("https://box.user.nl/remote.php/dav/files/daan/") requests: (QNetworkCookie("oc_sessionPassphrase=Uza4KLF%2BenTRpgfyQbzkzr7bG2y4BS42c96TBMXQij8gX%2Ba85hdM2vFHZHI1xjI%2FanZZRwHsND%2FG7tJrlDRLIe78TrHMRT%2BKv3joDO1rGIRYLekVKMlnBbPiXWuuYSIi; secure; HttpOnly; domain=box.user.nl; path=/"), QNetworkCookie("oc0se6n0vcqb=m2clco10srtqr4p50tdbgacfn6; secure; HttpOnly; domain=box.user.nl; path=/"))
12-30 13:37:07:747 [ info sync.networkjob ]: OCC::RequestEtagJob created for "https://box.user.nl" + "/" "OCC::Folder"
12-30 13:37:07:858 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:08:027 [ info sync.networkjob.etag ]: Request Etag of QUrl("https://box.user.nl/remote.php/dav/files/daan/") FINISHED WITH STATUS "OK"
12-30 13:37:08:036 [ debug sync.networkjob ] [ OCC::AbstractNetworkJob::slotFinished ]: Network job OCC::RequestEtagJob finished for "/"
12-30 13:37:09:860 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:10:930 [ info sync.accessmanager ]: 6 "PROPFIND" "https://box.user.nl/remote.php/dav/files/daan/" has X-Request-ID "582660e5-8793-43c6-abae-395c2b0dee81"
12-30 13:37:10:931 [ debug sync.cookiejar ] [ OCC::CookieJar::cookiesForUrl ]: QUrl("https://box.user.nl/remote.php/dav/files/daan/") requests: (QNetworkCookie("oc_sessionPassphrase=Uza4KLF%2BenTRpgfyQbzkzr7bG2y4BS42c96TBMXQij8gX%2Ba85hdM2vFHZHI1xjI%2FanZZRwHsND%2FG7tJrlDRLIe78TrHMRT%2BKv3joDO1rGIRYLekVKMlnBbPiXWuuYSIi; secure; HttpOnly; domain=box.user.nl; path=/"), QNetworkCookie("oc0se6n0vcqb=m2clco10srtqr4p50tdbgacfn6; secure; HttpOnly; domain=box.user.nl; path=/"))
12-30 13:37:10:931 [ info sync.networkjob ]: OCC::PropfindJob created for "https://box.user.nl" + "/" "OCC::QuotaInfo"
12-30 13:37:10:998 [ info sync.networkjob.propfind ]: PROPFIND of QUrl("https://box.user.nl/remote.php/dav/files/daan/") FINISHED WITH STATUS "OK"
12-30 13:37:10:998 [ debug sync.networkjob ] [ OCC::AbstractNetworkJob::slotFinished ]: Network job OCC::PropfindJob finished for "/"
12-30 13:37:11:862 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:13:862 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
12-30 13:37:15:865 [ warning gui.folderwatcher ]: Failed to create handle for "C:/Users/xxx/ownCloud/" , error: 5
- Web server error log:
None
- Server logfile: ownCloud log (data/owncloud.log):
{"reqId":"ukuhNZw5OXL5QJgvMoaV","level":4,"time":"2019-12-16T17:02:46+01:00","remoteAddr":"144.91.70.81","user":"willie","app":"webdav","method":"MKCOL","url":"\/remote.php\/dav\/files\/willie\/1.%20Foto,s\/Afrika%202016\/","message":"Exception: HTTP\/1.1 405 The resource you tried to create already exists: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\MethodNotAllowed\",\"Message\":\"The resource you tried to create already exists\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(586): Sabre\\\\DAV\\\\Server->createCollection('files\\\/willie\\\/1....', Object(Sabre\\\\DAV\\\\MkCol))\\n#1 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\CorePlugin->httpMkcol(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(464): Sabre\\\\DAV\\\\Server->emit('method:MKCOL', Array)\\n#3 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(241): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#4 \\\/var\\\/www\\\/html\\\/box\\\/apps\\\/dav\\\/lib\\\/Server.php(326): Sabre\\\\DAV\\\\Server->start()\\n#5 \\\/var\\\/www\\\/html\\\/box\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#6 \\\/var\\\/www\\\/html\\\/box\\\/remote.php(165): require_once('\\\/var\\\/www\\\/html\\\/b...')\\n#7 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php\",\"Line\":1181}"}
{"reqId":"cRtoctvaGphifzWOoYQa","level":4,"time":"2019-12-16T17:02:46+01:00","remoteAddr":"144.91.70.81","user":"willie","app":"webdav","method":"MKCOL","url":"\/remote.php\/dav\/files\/willie\/1.%20Foto,s\/Compleet%20foto%27s%20familiegeschiedenis\/laatste%20info%20stamboom\/","message":"Exception: HTTP\/1.1 405 The resource you tried to create already exists: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\MethodNotAllowed\",\"Message\":\"The resource you tried to create already exists\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(586): Sabre\\\\DAV\\\\Server->createCollection('files\\\/willie\\\/1....', Object(Sabre\\\\DAV\\\\MkCol))\\n#1 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(96): Sabre\\\\DAV\\\\CorePlugin->httpMkcol(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/var\\\/www\\\/html\\\/box\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.^C
