Your site says issues should be posted on github, but github says issues should be discussed first here.
So i’ll just put this here.
I’ve had my owncloud working just fine for the last 8 months.
I tried to update it and now it doesn’t work anymore, I’ve also tried going back to the old version but it doesn’t work anymore either. I’ve tried completely removing all the files and re-installing but nothing seems to resolve the issue.
- install docker owncloud
- setup nginx reverse proxy to connect to the port
- access owncloud through reverse proxy
you should see your files / the default files directory
it works if i go to the port directly,
you see no files when accessing through the reverse proxy,
Operating system: Open Media Vault V6
**Web server:**Nginx Proxy Manager
**Database:**mariaDB
ownCloud version: 10.9.0, 10.10.0
Where did you install ownCloud from: hub.docker
