Is there a way to disable the authentication for Owncloud?
For an internal setup we’d like to run Owncloud without having to provide credentials. Naturally that’s not an usual use case for Owncloud, but I’d still like to know whether it’s possible to configure it in that way.
It’s not directly possible (there are probably ways to hack around this) but if it’s only to make files available, you can use a sharing link for a folder. Except for a demo, what is the use case?
