J5fine
1
Hi, how can I disable integrity check for .htaccess.
Yes I have changed the file for the purpose of forcing SSL.
Or disabling banner (fixing invalid code integrity message) for administrators?
https://doc.owncloud.org/server/10.0/admin_manual/issues/code_signing.html
ownCloud 10.0.10
BR Janez
i have the following line in my .htaccess:
DO NOT CHANGE ANYTHING ABOVE THIS LINE
Maybe it helps doing your modification to this file below this line?
J5fine
3
in 10.0.10 there is no line
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
by default.
And yes it helped
. Tnx.
Even if not recommended, an optional way is adding .htaccess to the exclude list in config.php.
See also: config.sample.php
'integrity.excluded.files' =>
array (
'.DS_Store',
'Thumbs.db',
'.directory',
'.webapp',
'.htaccess',
'.user.ini',
