Docker HTTPS deployment
Hi All, I am currently in the business of moving all my old ESXi VMs over to docker or KVM, and I am currently moving owncloud to docker.
Or so I thought.
Following the official documentation for a docker install here : https://doc.owncloud.com/server/10.0/administration_manual/installation/docker/
I see no mention of SSL \ HTTPS support.
Does that mean I have to do a manual install and create my own docker image for that purpose ? Doesn’t sound very futureproof for deploying owncloud with docker :slight_smile:
maybe the following comment gives some insight on this topic?
You should use a reverse proxy for the SSL termination. Since this is pretty common for Docker setups we have dropped the whole SSL parts from this Docker image.
You can take a look at Docker Series Pt.2: Set up ownCloud + Traefik as a Reverse Proxy with Let's Encrypt SSL - ownCloud to get an idea how to build this setup with Traefik.
which i have found in:
