Introduction
I’m a newbie in using Owncloud technology, I installed it on docker using this official guide ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company) and there are few things I don’t understand, so here are my question, I will be grateful to any answer.
Questions
- Everytime I stop/start or down/up the trio owncloud/mariadb/redis using docker-compose and I go back the gui, It asks me to define admin user such as it was the first time I launch it. No problem with the data persistence, files and folder are saved.
2.By default, the installation select SQLITE as database type but the installation assume that we use mariadb instead, should I select mariadb in the database type? Selecting mariadb give me this error: Error while trying to create admin user: Failed to connect to the database: An exception occured in driver: SQLSTAT[HY000][220] No such file or directory.
3.When I down/up the trio using docker-compose, I loose all extra apps such as calendar or gallery. Is it possible to keep the persistence?
4.I tried to add a local folder as an external storage but following this guide don’t work: ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company). Travelling the github yesterday I understood that this feature was not available anymore fore security reason, Am I right?
CentOS Linux 7 (Core)
CPE OS Name: cpe:/o:centos:centos:7
Kernel: Linux 3.10.0-327.el7.x86_64
Architecture: x86-64
webhippie/mariadb
used with:
webhippie/redis
owncloud/server:10.0.4
“system”: {
“trusted_domains”: [
“192.168.0.11”
“datadirectory”: “/mnt/data/files”,
“overwrite.cli.url”: “http://192.168.0.11”,
“dbtype”: “sqlite3”,
“version”: “10.0.4.4”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“instanceid”: “ocbhyy3g4bcc”,
“logtimezone”: “UTC”,
“installed”: true
Vivaldi 1.10.867.38 (Stable channel) (32-bit)
Windows 7 Pro 64bits
