Installation according to: https://doc.owncloud.org/server/10.4/admin_manual/installation/docker/
- docker pull owncloud/server
- wget https://raw.githubusercontent.com/owncloud/docs/master/modules/admin_manual/examples/installation/docker/docker-compose.yml
- vi .env
OWNCLOUD_VERSION=18.09.9
OWNCLOUD_DOMAIN=localhost
ADMIN_USERNAME=***
ADMIN_PASSWORD=***
HTTP_PORT=8080
HTTPS_PORT=443 - docker compose up -d
A docker container shoud be created
When I do: docker-compose up -d
I get the following Errorroot@testsrv:~# cd /home/owncloud-docker-server/
root@testsrv:/home/owncloud-docker-server# ll
total 8
drwxr-xr-x 2 root root 44 Feb 16 15:19 ./
drwxr-xr-x 4 root root 48 Feb 16 15:04 …/
-rw-r–r-- 1 root root 1650 Feb 16 15:06 docker-compose.yml
-rwx------ 1 root root 124 Feb 16 15:19 .env*
root@testsrv:/home/owncloud-docker-server# chmod 777 .env
root@testsrv:/home/owncloud-docker-server# docker-compose up -d
Traceback (most recent call last):
File “/snap/docker/423/bin/docker-compose”, line 11, in
load_entry_point(‘docker-compose==1.23.2’, ‘console_scripts’, ‘docker-compose’)()
File “/snap/docker/423/lib/python2.7/site-packages/compose/cli/main.py”, line 71, in main
command()
File “/snap/docker/423/lib/python2.7/site-packages/compose/cli/main.py”, line 124, in perform_command
project = project_from_options(’.’, options)
File “/snap/docker/423/lib/python2.7/site-packages/compose/cli/command.py”, line 27, in project_from_options
environment = Environment.from_env_file(override_dir or project_dir)
File “/snap/docker/423/lib/python2.7/site-packages/compose/config/environment.py”, line 61, in from_env_file
instance = _initialize()
File “/snap/docker/423/lib/python2.7/site-packages/compose/config/environment.py”, line 57, in _initialize
return cls(env_vars_from_file(env_file_path))
File “/snap/docker/423/lib/python2.7/site-packages/compose/config/environment.py”, line 35, in env_vars_from_file
with contextlib.closing(codecs.open(filename, ‘r’, ‘utf-8-sig’)) as fileobj:
File “/snap/docker/423/usr/lib/python2.7/codecs.py”, line 896, in open
file = builtin.open(filename, mode, buffering)
IOError: [Errno 13] Permission denied: u’./.env’
Ubuntu Server 19.10 (64bit)
docker
docker
docker
total 8
command()
fresh install
docker
