- Installed docker owncloud 10.0.9 version.
- docker-compose exec owncloud occ maintenance:mode --on
- docker-compose down
- Edited 10.0.9 to 10.0.10 in .env file
- docker-compose up show errors
~/owncloud-docker-server$ docker-compose up
Creating network "ownclouddockerserver_default" with the default driver
Pulling owncloud (owncloud/server:10.0.10)...
10.0.10: Pulling from owncloud/server
124c757242f8: Pull complete
9d866f8bde2a: Pull complete
fa3f2f277e67: Pull complete
398d32b153e8: Pull complete
afde35469481: Pull complete
ee4940ea69ce: Pull complete
753ed9df06b3: Pull complete
a36e4e641ba9: Pull complete
f5039da8a656: Pull complete
a9fb01f99fff: Pull complete
edfe2b9fe5f2: Pull complete
1537f64f08da: Pull complete
5a74e2413a2a: Pull complete
43bb49accaf8: Pull complete
ab29203d6fdb: Pull complete
c0b1b45e41a7: Pull complete
Digest: sha256:8a4ceac690fd1703e525db5cd77f66da70185668059b31af06aef5d1748fb1b3
Creating ownclouddockerserver_redis_1 ... done
Creating ownclouddockerserver_db_1 ... done
Creating ownclouddockerserver_owncloud_1 ... done
Attaching to ownclouddockerserver_db_1, ownclouddockerserver_redis_1, ownclouddockerserver_owncloud_1
db_1 | Cron is enabled, launching it!
db_1 | 200713 11:09:33 mysqld_safe Logging to '/var/lib/mysql/680d7c802e7f.err'.
owncloud_1 | Creating volume folders...
redis_1 | 12:C 13 Jul 11:09:34.760 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
db_1 | 200713 11:09:33 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
owncloud_1 | Creating hook folders...
redis_1 | 12:C 13 Jul 11:09:34.760 # Redis version=4.0.2, bits=64, commit=28ec1afc, modified=0, pid=12, just started
redis_1 | 12:C 13 Jul 11:09:34.760 # Configuration loaded
redis_1 | 12:M 13 Jul 11:09:34.762 * Running mode=standalone, port=6379.
owncloud_1 | Waiting for MySQL...
owncloud_1 | wait-for-it: waiting 180 seconds for db:3306
redis_1 | 12:M 13 Jul 11:09:34.762 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
redis_1 | 12:M 13 Jul 11:09:34.762 # Server initialized
redis_1 | 12:M 13 Jul 11:09:34.762 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
redis_1 | 12:M 13 Jul 11:09:34.762 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
owncloud_1 | wait-for-it: db:3306 is available after 0 seconds
redis_1 | 12:M 13 Jul 11:09:34.762 * Ready to accept connections
owncloud_1 | Waiting for Redis...
owncloud_1 | wait-for-it: waiting 60 seconds for redis:6379
owncloud_1 | wait-for-it: redis:6379 is available after 0 seconds
owncloud_1 | Removing custom folder...
owncloud_1 | Linking custom folder...
owncloud_1 | Removing config folder...
owncloud_1 | Linking config folder...
owncloud_1 | Writing config file...
owncloud_1 | Fixing base perms...
owncloud_1 | Fixing data perms...
owncloud_1 | Fixing hook perms...
owncloud_1 | Upgrading server database...
owncloud_1 | ownCloud or one of the apps require upgrade - only a limited number of commands are available
owncloud_1 | You may use your browser or the occ upgrade command to do the upgrade
owncloud_1 | 2020-07-13T11:10:01+00:00 Set log level to debug
owncloud_1 | 2020-07-13T11:10:01+00:00 Turned on maintenance mode
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Repair MySQL database engine
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Repair MySQL collation
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair info: All tables already have the correct collation -> nothing to do
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Repair SQLite autoincrement
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Repair orphaned reshare
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Repair duplicate entries in oc_lucene_status
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair info: lucene_status table does not exist -> nothing to do
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair step: Upgrade app code from the marketplace
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair info: Using market to update existing apps
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair info: Attempting to update the following existing compatible apps from market:
owncloud_1 | 2020-07-13T11:10:01+00:00 Repair info: Fetching app from market: activity
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info:
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: comments
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (comments) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: customgroups
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: dav
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (dav) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: federatedfilesharing
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (federatedfilesharing) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: federation
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (federation) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_external
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files_external) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_pdfviewer
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_sharing
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files_sharing) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_texteditor
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_trashbin
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files_trashbin) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_versions
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files_versions) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: files_videoplayer
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (files_videoplayer) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: firstrunwizard
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: App (firstrunwizard) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: gallery
owncloud_1 | 2020-07-13T11:10:02+00:00 Repair info: Fetching app from market: market
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: Fetching app from market: notifications
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App (notifications) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: Fetching app from market: provisioning_api
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App (provisioning_api) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: Fetching app from market: systemtags
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App (systemtags) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: Fetching app from market: templateeditor
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: Fetching app from market: updatenotification
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App (updatenotification) is not known at the marketplace.
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: activity
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: comments
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: customgroups
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: dav
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: federatedfilesharing
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: federation
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_external
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_pdfviewer
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_sharing
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_texteditor
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_trashbin
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_versions
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: files_videoplayer
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: firstrunwizard
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: gallery
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: notifications
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: provisioning_api
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: systemtags
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: templateeditor
owncloud_1 | 2020-07-13T11:10:04+00:00 Repair info: App was not updated: updatenotification
owncloud_1 | 2020-07-13T11:10:04+00:00 Updating database schema
owncloud_1 | 2020-07-13T11:10:04+00:00 Updated database
owncloud_1 | 2020-07-13T11:10:04+00:00 Updating <dav> ...
owncloud_1 | 2020-07-13T11:10:13+00:00 Repair step: Remove invalid calendar and addressbook shares
owncloud_1 | 2020-07-13T11:10:13+00:00 Repair info: ... for principal 'principals/groups/sensitive+information'
owncloud_1 | 2020-07-13T11:10:13+00:00 Repair info: ... for principal 'principals/users/sensitive+information'
owncloud_1 | 2020-07-13T11:10:13+00:00 Updated <dav> to 0.4.0
owncloud_1 | 2020-07-13T11:10:13+00:00 Updating <files_sharing> ...
owncloud_1 | 2020-07-13T11:10:14+00:00 Updated <files_sharing> to 0.11.0
owncloud_1 | 2020-07-13T11:10:14+00:00 Updating <notifications> ...
owncloud_1 | 2020-07-13T11:10:14+00:00 Updated <notifications> to 0.3.5
owncloud_1 | 2020-07-13T11:10:14+00:00 Repair step: Repair mime types
owncloud_1 | 2020-07-13T11:10:14+00:00 Repair step: Detect file cache entries with path that does not match parent-child relationships
owncloud_1 | 2020-07-13T11:10:14+00:00 Repair step: Generate ETags for file where no ETag is present.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: ETags have been fixed for 0 files/folders.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Clean tags and favorites
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: 0 tags of deleted users have been removed.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: 0 tags for delete files have been removed.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: 0 tag entries for deleted tags have been removed.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: 0 tags with no entries have been removed.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Drop old database tables
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database tables
owncloud_1 | 2020-07-13T11:10:16+00:00 Starting ...
owncloud_1 | 0/28 [>-] 0%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: calendar_calendars
owncloud_1 | 1/28 [=>] 3%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: calendar_objects
owncloud_1 | 2/28 [==>] 7%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: calendar_share_calendar
owncloud_1 | 3/28 [===>] 10%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: calendar_share_event
owncloud_1 | 4/28 [====>] 14%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: file_map
owncloud_1 | 5/28 [=====>] 17%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: foldersize
owncloud_1 | 6/28 [======>] 21%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: fscache
owncloud_1 | 7/28 [=======>] 25%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: gallery_sharing
owncloud_1 | 8/28 [========>] 28%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: locks
owncloud_1 | 9/28 [=========>] 32%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: log
owncloud_1 | 10/28 [==========>] 35%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: media_albums
owncloud_1 | 11/28 [===========>] 39%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: media_artists
owncloud_1 | 12/28 [============>] 42%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: media_sessions
owncloud_1 | 13/28 [=============>] 46%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: media_songs
owncloud_1 | 14/28 [==============>] 50%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: media_users
owncloud_1 | 15/28 [===============>] 53%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: permissions
owncloud_1 | 16/28 [================>] 57%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: pictures_images_cache
owncloud_1 | 17/28 [=================>] 60%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: principalgroups
owncloud_1 | 18/28 [==================>] 64%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: principals
owncloud_1 | 19/28 [===================>] 67%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: queuedtasks
owncloud_1 | 20/28 [====================>] 71%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: sharing
owncloud_1 | 21/28 [=====================>] 75%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: clndr_calendars
owncloud_1 | 22/28 [======================>] 78%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: clndr_objects
owncloud_1 | 23/28 [=======================>] 82%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: clndr_share_event
owncloud_1 | 24/28 [========================>] 85%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: clndr_share_calendar
owncloud_1 | 25/28 [=========================>] 89%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: clndr_repeat
owncloud_1 | 26/28 [==========================>] 92%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: contacts_addressbooks
owncloud_1 | 27/28 [===========================>] 96%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Drop old database table: contacts_cards
owncloud_1 | 28/28 [============================] 100%2020-07-13T11:10:16+00:00
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Drop old background jobs
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Remove getetag entries in properties table
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair info: Removed 0 unneeded "{DAV:}getetag" entries from properties table.
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Repair outdated OCS IDs
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Repair invalid shares
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Remove old share propagation app entries
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Move user avatars outside the homes to the new location
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Remove shares of a users root folder
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Repair unmerged shares
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Disable extra themes
owncloud_1 | 2020-07-13T11:10:16+00:00 Repair step: Repair sub shares
owncloud_1 | 2020-07-13T11:10:16+00:00 Starting code integrity check...
owncloud_1 | 2020-07-13T11:10:21+00:00 Finished code integrity check
owncloud_1 | 2020-07-13T11:10:21+00:00 Update successful
owncloud_1 | 2020-07-13T11:10:21+00:00 Turned off maintenance mode
owncloud_1 | 2020-07-13T11:10:21+00:00 Reset log level
owncloud_1 | ownCloud is already latest version
owncloud_1 | Writing objectstore config...
owncloud_1 | Writing php config...
owncloud_1 | Updating htaccess config...
owncloud_1 | .htaccess has been updated
owncloud_1 | Writing apache config...
owncloud_1 | Enabling cron background...
owncloud_1 | Set mode for background jobs to 'cron'
owncloud_1 | Touching cron configs...
owncloud_1 | Starting cron daemon...
owncloud_1 | Starting apache daemon...
owncloud_1 | [Mon Jul 13 11:10:24.962666 2020] [mpm_prefork:notice] [pid 444] AH00163: Apache/2.4.29 (Ubuntu) configured -- resuming normal operations
owncloud_1 | [Mon Jul 13 11:10:24.962721 2020] [core:notice] [pid 444] AH00094: Command line: '/usr/sbin/apache2 -f /etc/apache2/apache2.conf -D FOREGROUND'
owncloud.log
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:01+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"starting upgrade from 10.0.9.5 to 10.0.10.4"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:04+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: starting 20180622095921 from app dav"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:13+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: completed 20180622095921 from app dav"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:13+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: starting 20171115154900 from app files_sharing"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:14+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: completed 20171115154900 from app files_sharing"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:14+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: starting 20171215103657 from app files_sharing"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":0,"time":"2020-07-13T11:10:14+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Migrations: completed 20171215103657 from app files_sharing"}
{"reqId":"eT3MLBfbY3CvLujiXXur","level":3,"time":"2020-07-13T11:10:16+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"str_repeat(): Second argument has to be greater than or equal to 0 at \/var\/www\/owncloud\/lib\/composer\/symfony\/console\/Helper\/ProgressBar.php#512"}
