Please help us by providing the following info. Before posting please also check the pinned "Known issues" threads and make sure that you're running the latest available version for your oC release: https://owncloud.org/changelog/
1. Type mydomain.com in the Browser
2. press enter
Or
1.Login in my sync programm (Win10 & Kubuntu 16.04)
It should connect to the server
Error: Timeout
With the ip i can still connect
Operating system: Raspbian
Web server: nginx
Database: mysql
PHP version: idk
ownCloud version (see ownCloud admin page): 9.1.0 (stable)
logfile
{"reqId":"HaNPRquBryba40UOcOB+","remoteAddr":"192.168.178.21","app":"PHP","message":"Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php:\/\/input stream instead. at Unknown#0","level":3,"time":"2016-09-12T19:03:25+00:00","method":"POST","url":"\/index.php\/settings\/admin\/mailtest","user":"admin"}
{"reqId":"\/FKWn\/rEVQen\/g6D7gOv","remoteAddr":"192.168.178.21","app":"index","message":"Exception: {\"Exception\":\"Doctrine\\DBAL\\Exception\\DriverException\",\"Message\":\"An exception occurred while executing 'SELECT \\"uid\\", \\"displayname\\" FROM \\"oc_users\\" WHERE LOWER(\\"uid\\") = LOWER(?)' with params [\\"admin\\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed\",\"Code\":0,\"Trace\":\"#0 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractSQLiteDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT \\"uid\\", \\"...', Array)\n#2 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/db\\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(288): OC\\User\\Session->getUser()\n#8 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(105): OC_App::getEnabledApps()\n#9 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/user.php(127): OC_App::loadApps(Array)\n#10 \\/var\\/www\\/owncloud\\/lib\\/base.php(640): OC_User::setupBackends()\n#11 \\/var\\/www\\/owncloud\\/lib\\/base.php(967): OC::init()\n#12 \\/var\\/www\\/owncloud\\/index.php(37): require_once('\\/var\\/www\\/ownclo...')\n#13 {main}\",\"File\":\"\\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Driver\\/AbstractSQLiteDriver.php\",\"Line\":85}","level":3,"time":"2016-09-12T19:46:04+00:00","method":"POST","url":"\/index.php\/settings\/ajax\/enableapp.php","user":"admin"}
{"reqId":"aCCJMm1eZjxzHZS2WKEL","remoteAddr":"192.168.178.21","app":"index","message":"Exception: {\"Exception\":\"Doctrine\\DBAL\\Exception\\DriverException\",\"Message\":\"An exception occurred while executing 'SELECT \\"uid\\", \\"displayname\\" FROM \\"oc_users\\" WHERE LOWER(\\"uid\\") = LOWER(?)' with params [\\"admin\\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed\",\"Code\":0,\"Trace\":\"#0 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractSQLiteDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT \\"uid\\", \\"...', Array)\n#2 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/db\\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(288): OC\\User\\Session->getUser()\n#8 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(105): OC_App::getEnabledApps()\n#9 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/user.php(127): OC_App::loadApps(Array)\n#10 \\/var\\/www\\/owncloud\\/lib\\/base.php(640): OC_User::setupBackends()\n#11 \\/var\\/www\\/owncloud\\/lib\\/base.php(967): OC::init()\n#12 \\/var\\/www\\/owncloud\\/index.php(37): require_once('\\/var\\/www\\/ownclo...')\n#13 {main}\",\"File\":\"\\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Driver\\/AbstractSQLiteDriver.php\",\"Line\":85}","level":3,"time":"2016-09-12T19:46:05+00:00","method":"POST","url":"\/index.php\/settings\/ajax\/enableapp.php","user":"admin"}
{"reqId":"V0lDiieNinio3mUXCC+H","remoteAddr":"192.168.178.21","app":"PHP","message":"Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT \"uid\", \"displayname\" FROM \"oc_users\" WHERE LOWER(\"uid\") = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed at \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractSQLiteDriver.php#85","level":3,"time":"2016-09-12T19:48:44+00:00","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","user":"admin"}
{"reqId":"1jq83IBOJYBxXmyET+PT","remoteAddr":"192.168.178.21","app":"PHP","message":"Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT \"uid\", \"displayname\" FROM \"oc_users\" WHERE LOWER(\"uid\") = LOWER(?)' with params [\"admin\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed at \/var\/www\/owncloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractSQLiteDriver.php#85","level":3,"time":"2016-09-12T19:48:44+00:00","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","user":"admin"}
{"reqId":"fhj7ZB6uRrAnR90tm3Ea","remoteAddr":"192.168.178.21","app":"index","message":"Exception: {\"Exception\":\"Doctrine\\DBAL\\Exception\\DriverException\",\"Message\":\"An exception occurred while executing 'SELECT \\"uid\\", \\"displayname\\" FROM \\"oc_users\\" WHERE LOWER(\\"uid\\") = LOWER(?)' with params [\\"admin\\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed\",\"Code\":0,\"Trace\":\"#0 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractSQLiteDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT \\"uid\\", \\"...', Array)\n#2 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/db\\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(288): OC\\User\\Session->getUser()\n#8 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(105): OC_App::getEnabledApps()\n#9 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/user.php(127): OC_App::loadApps(Array)\n#10 \\/var\\/www\\/owncloud\\/lib\\/base.php(640): OC_User::setupBackends()\n#11 \\/var\\/www\\/owncloud\\/lib\\/base.php(967): OC::init()\n#12 \\/var\\/www\\/owncloud\\/index.php(37): require_once('\\/var\\/www\\/ownclo...')\n#13 {main}\",\"File\":\"\\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Driver\\/AbstractSQLiteDriver.php\",\"Line\":85}","level":3,"time":"2016-09-12T19:48:44+00:00","method":"GET","url":"\/index.php\/logout?requesttoken=JChpGSYmSSAFMG8AJVQ%2BfFMoNVUFIS0nZH9%2BMjwpAls%3D%3AHO\/LLPbzUdWBGdRO8fO8gCyt570CNK37ih775g8jxys%3D","user":"admin"}
{"reqId":"u3fR2OENk9z6jquD\/wfj","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T19:48:44+00:00","method":"GET","url":"\/","user":"--"}
{"reqId":"nOPT34KjL8PfmY27R04X","remoteAddr":"192.168.178.21","app":"index","message":"Exception: {\"Exception\":\"Doctrine\\DBAL\\Exception\\DriverException\",\"Message\":\"An exception occurred while executing 'SELECT \\"uid\\", \\"displayname\\" FROM \\"oc_users\\" WHERE LOWER(\\"uid\\") = LOWER(?)' with params [\\"admin\\"]:\n\nSQLSTATE[HY000]: General error: 17 database schema has changed\",\"Code\":0,\"Trace\":\"#0 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractSQLiteDriver->convertException('An exception oc...', Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Statement.php(175): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOSqlite\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), 'SELECT \\"uid\\", \\"...', Array)\n#2 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/db\\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(223): OC_DB_StatementWrapper->execute(Array)\n#4 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Database.php(270): OC\\User\\Database->loadUser('admin')\n#5 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Manager.php(139): OC\\User\\Database->userExists('admin')\n#6 \\/var\\/www\\/owncloud\\/lib\\/private\\/User\\/Session.php(192): OC\\User\\Manager->get('admin')\n#7 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(288): OC\\User\\Session->getUser()\n#8 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/app.php(105): OC_App::getEnabledApps()\n#9 \\/var\\/www\\/owncloud\\/lib\\/private\\/legacy\\/user.php(127): OC_App::loadApps(Array)\n#10 \\/var\\/www\\/owncloud\\/lib\\/base.php(640): OC_User::setupBackends()\n#11 \\/var\\/www\\/owncloud\\/lib\\/base.php(967): OC::init()\n#12 \\/var\\/www\\/owncloud\\/index.php(37): require_once('\\/var\\/www\\/ownclo...')\n#13 {main}\",\"File\":\"\\/var\\/www\\/owncloud\\/3rdparty\\/doctrine\\/dbal\\/lib\\/Doctrine\\/DBAL\\/Driver\\/AbstractSQLiteDriver.php\",\"Line\":85}","level":3,"time":"2016-09-12T19:48:44+00:00","method":"POST","url":"\/index.php\/settings\/ajax\/enableapp.php","user":"admin"}
{"reqId":"dmL68nWvoKa7hMGmpqlw","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T19:59:57+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"rQD\/enFHVUhWg\/1klyvb","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:09+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"\/01lD9mn+sfhGoWjQhjV","remoteAddr":"192.168.178.21","app":"no app in context","message":"OCA\Files_Antivirus\AvirWrapper OCA\Files_Antivirus\AvirWrapper::fopen The antivirus executable could not be found at \/usr\/bin\/clamscan","level":2,"time":"2016-09-12T20:00:31+00:00","method":"POST","url":"\/index.php\/login","user":"PatrickDavid"}
{"reqId":"\/01lD9mn+sfhGoWjQhjV","remoteAddr":"192.168.178.21","app":"no app in context","message":"OCA\Files_Antivirus\AvirWrapper OCA\Files_Antivirus\AvirWrapper::fopen The antivirus executable could not be found at \/usr\/bin\/clamscan","level":2,"time":"2016-09-12T20:00:37+00:00","method":"POST","url":"\/index.php\/login","user":"PatrickDavid"}
{"reqId":"TsP1fQBoJd0d7oGCS+fT","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:37+00:00","method":"GET","url":"\/","user":"--"}
{"reqId":"\/01lD9mn+sfhGoWjQhjV","remoteAddr":"192.168.178.21","app":"no app in context","message":"OCA\Files_Antivirus\AvirWrapper OCA\Files_Antivirus\AvirWrapper::fopen The antivirus executable could not be found at \/usr\/bin\/clamscan","level":2,"time":"2016-09-12T20:00:38+00:00","method":"POST","url":"\/index.php\/login","user":"PatrickDavid"}
{"reqId":"\/01lD9mn+sfhGoWjQhjV","remoteAddr":"192.168.178.21","app":"no app in context","message":"OCA\Files_Antivirus\AvirWrapper OCA\Files_Antivirus\AvirWrapper::fopen The antivirus executable could not be found at \/usr\/bin\/clamscan","level":2,"time":"2016-09-12T20:00:41+00:00","method":"POST","url":"\/index.php\/login","user":"PatrickDavid"}
{"reqId":"rc8+RwE5KrD53fvZMPbJ","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:41+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"pnQ7DFLYyrLtkNmhRRb+","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:43+00:00","method":"GET","url":"\/","user":"--"}
{"reqId":"XRg8Zzl97m8Cb+y\/zNr\/","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:44+00:00","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=de6e2330ac40d6db98922bfd34c6bee1","user":"--"}
{"reqId":"nZL4jb14PIPMS7oTVgVl","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:00:45+00:00","method":"GET","url":"\/index.php\/core\/js\/oc.js?v=de6e2330ac40d6db98922bfd34c6bee1","user":"--"}
{"reqId":"44Rk4+7NjqUNMVC+\/LCM","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:01:13+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"Vv6I46EkwbJoH2l9r7A5","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:01:45+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"dmtFn1XNfXx6FA6oK9Qu","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:02:17+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"\/civyfSxFc+z14ziRZ1V","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:02:49+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"q762W\/SwlF2AaeCQmSWR","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:03:21+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"4WWYYhFRv9gIuEEuKhpt","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:03:53+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"Ywm69GlVdo5FcsOChmc5","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:04:25+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"CLQfwIMv38yNQLAn9eQt","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:04:57+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"jwePGrMFT7s98GvBvxKv","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:05:29+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"6porfJNUdZP2JXGUTZEI","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:06:01+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"0ujS7tvvtCUbcpAkCSD1","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:06:33+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"+IT+lnyP4UvOrHrF70Ka","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:07:05+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"DFSYXt5RrafmDegVAgxE","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:07:37+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"KRP4wl+\/7woYlPv99WbG","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:08:09+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"RFHNSlq+Jl2OCvaHs0KQ","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:08:41+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"mw9cFiFTCbwwDUB+GdP2","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:09:13+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"K5OaLqBwXoHJqh7G03CK","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:09:45+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"E1cxF\/KoqBa4ZyrHIssC","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:10:17+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"M8kWJSo51tn2Rhc1Ovxr","remoteAddr":"87.165.71.229","app":"core","message":"Trusted domain error. \"87.165.71.229\" tried to access using \"owncloud.ddnss.org\" as host.","level":2,"time":"2016-09-12T20:10:49+00:00","method":"GET","url":"\/status.php","user":"--"}
Integrity status for oC9+
paste the results here.
