- Try to login via web address with active directory account
User should be able to login and see their files.
Browser gives wheel of death and eventually returns “err_empty_response”
Ubuntu 14.04LTS
Apache (I think)
Unknown
9.1
No errors found
This option isn’t available and I get Sorry get an error could not open input file: occ from comand line
"system": {
"updatechecker": false,
"instanceid": "ocow55fosl6g",
"trusted_domains": [
"mecloud.mysite.com",
"192.168.10.132",
"localhost",
"svr-cloud"
"datadirectory": "\/mnt\/dfsMeCloud\/data",
"overwrite.cli.url": "https:\/\/mecloud.mysite.com\/owncloud",
"dbtype": "mysql",
"version": "9.1.0.15",
"dbname": "oc",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "smtp",
"mail_from_address": "mecloud",
"mail_domain": "mysite.com",
"mail_smtphost": "mysite-com.mail.protection.outlook.com",
"mail_smtpport": "25",
"loglevel": 3,
"log_rotate_size": 104857600,
"maintenance": false,
"enable_certificate_management": true,
"mail_smtpsecure": "tls"
Enabled:
- activity: 2.3.2
- dav: 0.2.5
- federatedfilesharing: 0.3.0
- files: 1.5.1
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_trashbin: 0.9.0
- files_videoplayer: 0.9.8
- provisioning_api: 0.5.0
- templateeditor: 0.1
- updatenotification: 0.2.1
- user_ldap: 0.9.0
Disabled:
- comments
- encryption
- external
- federation
- files_antivirus
- files_external
- files_texteditor
- files_versions
- firstrunwizard
- gallery
- notifications
- systemtags
- user_external
yes smb.
no
yes LDAP (active directory)
Edge / Chrome
Apart from asking me to supply things I can’t supply… Here’s the story.
This is an elderly version of OwnCloud (I know this), On friday we installed the latest windows updates and rebooted all our servers (including our domain controllers). Since then only users created on the OwnCloud system itself i.e. standalone users are able to login.
I’ve run tests from within OwnCloud to prove the connection via LDAP with the domain controller and these all pass. I am at a complete loss as to know what isn’t working or how to fix it.
I should add that if I am logged in with an Admin account and I try to list the users nothing happens and eventually it gives up.
Please help!
Kind regards,
Paul.
