Double hop, to X (production) major code integrity check failures
  1. update to 9.18 and then 10.0.0.7 (production)
  2. finish update with occ upgrade
Normal operation
Message on the GUI after logging in
Operating system: Debian
Web server: Apache
Database: mysql
PHP version: 7.0
ownCloud version: (see ownCloud admin page) 10.0.0.7
Updated from an older ownCloud or fresh install: update
Where did you install ownCloud from: first 9.0.1 (23 December), to 9.1.8 then 10.0.7
Are you using external storage, if yes which one: local/smb/sftp/… no
Are you using encryption: yes/no no
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/… yes ldap
LDAP configuration (delete this part if not used) is working fine
Technical information
them.
Results
  • core
    • INVALID_HASH
      • updater/README.md
      • updater/app/bootstrap.php
      • updater/app/config/container.php
      • updater/pub/js/main.js
      • updater/src/Command/BackupDataCommand.php
      • updater/src/Command/BackupDbCommand.php
      • updater/src/Command/CheckSystemCommand.php
      • updater/src/Command/CheckpointCommand.php
      • updater/src/Command/CleanCacheCommand.php
      • updater/src/Command/Command.php
      • updater/src/Command/DetectCommand.php
      • updater/src/Command/ExecuteCoreUpgradeScriptsCommand.php
      • updater/src/Command/InfoCommand.php
      • updater/src/Command/MaintenanceModeCommand.php
      • updater/src/Command/PostUpgradeCleanupCommand.php
      • updater/src/Command/PostUpgradeRepairCommand.php
      • updater/src/Command/PreUpgradeRepairCommand.php
      • updater/src/Command/RestartWebServerCommand.php
      • updater/src/Command/StartCommand.php
      • updater/src/Command/UpdateConfigCommand.php
      • updater/src/Console/Application.php
      • updater/src/Controller/DownloadController.php
      • updater/src/Controller/IndexController.php
      • updater/src/Formatter/HtmlOutputFormatter.php
      • updater/src/Http/Request.php
      • updater/src/Resources/views/base.php
      • updater/src/Resources/views/partials/inner.php
      • updater/src/Resources/views/partials/login.php
      • updater/src/Utils/AppManager.php
      • updater/src/Utils/Checkpoint.php
      • updater/src/Utils/Collection.php
      • updater/src/Utils/ConfigReader.php
      • updater/src/Utils/DocLink.php
      • updater/src/Utils/Feed.php
      • updater/src/Utils/Fetcher.php
      • updater/src/Utils/FilesystemHelper.php
      • updater/src/Utils/Locator.php
      • updater/src/Utils/OccRunner.php
      • updater/src/Utils/Registry.php
      • updater/src/Utils/ZipExtractor.php
      • updater/vendor/autoload.php
      • updater/vendor/composer/autoload_files.php
      • updater/vendor/composer/autoload_psr4.php
      • updater/vendor/composer/autoload_real.php
      • updater/vendor/composer/installed.json
      • updater/vendor/paragonie/random_compat/CHANGELOG.md
      • updater/vendor/paragonie/random_compat/ERRATA.md
      • updater/vendor/paragonie/random_compat/lib/random.php
      • updater/vendor/react/promise/CHANGELOG.md
      • updater/vendor/react/promise/composer.json
      • updater/vendor/react/promise/src/LazyPromise.php
      • updater/vendor/react/promise/src/Promise.php
      • updater/vendor/react/promise/src/functions.php
      • updater/vendor/symfony/console/Application.php
      • updater/vendor/symfony/console/CHANGELOG.md
      • updater/vendor/symfony/console/Command/Command.php
      • updater/vendor/symfony/console/Command/HelpCommand.php
      • updater/vendor/symfony/console/Command/ListCommand.php
      • updater/vendor/symfony/console/Descriptor/ApplicationDescription.php
      • updater/vendor/symfony/console/Descriptor/Descriptor.php
      • updater/vendor/symfony/console/Descriptor/MarkdownDescriptor.php
      • updater/vendor/symfony/console/Descriptor/TextDescriptor.php
      • updater/vendor/symfony/console/Formatter/OutputFormatter.php
      • updater/vendor/symfony/console/Formatter/OutputFormatterStyleStack.php
      • updater/vendor/symfony/console/Helper/DescriptorHelper.php
      • updater/vendor/symfony/console/Helper/DialogHelper.php
      • updater/vendor/symfony/console/Helper/Helper.php
      • updater/vendor/symfony/console/Helper/HelperSet.php
      • updater/vendor/symfony/console/Helper/ProgressBar.php
      • updater/vendor/symfony/console/Helper/ProgressHelper.php
      • updater/vendor/symfony/console/Helper/QuestionHelper.php
      • updater/vendor/symfony/console/Helper/SymfonyQuestionHelper.php
      • updater/vendor/symfony/console/Helper/Table.php
      • updater/vendor/symfony/console/Helper/TableCell.php
      • updater/vendor/symfony/console/Helper/TableHelper.php
      • updater/vendor/symfony/console/Helper/TableStyle.php
      • updater/vendor/symfony/console/Input/ArgvInput.php
      • updater/vendor/symfony/console/Input/ArrayInput.php
      • updater/vendor/symfony/console/Input/Input.php
      • updater/vendor/symfony/console/Input/InputDefinition.php
      • updater/vendor/symfony/console/Input/InputInterface.php
      • updater/vendor/symfony/console/Input/StringInput.php
      • updater/vendor/symfony/console/LICENSE
      • updater/vendor/symfony/console/Output/ConsoleOutput.php
      • updater/vendor/symfony/console/Output/OutputInterface.php
      • updater/vendor/symfony/console/Question/ChoiceQuestion.php
      • updater/vendor/symfony/console/Question/Question.php
      • updater/vendor/symfony/console/Shell.php
      • updater/vendor/symfony/console/Style/SymfonyStyle.php
      • updater/vendor/symfony/console/Tester/ApplicationTester.php
      • updater/vendor/symfony/console/Tester/CommandTester.php
      • updater/vendor/symfony/console/composer.json
      • updater/vendor/symfony/process/ExecutableFinder.php
      • updater/vendor/symfony/process/PhpExecutableFinder.php
      • updater/vendor/symfony/process/PhpProcess.php
      • updater/vendor/symfony/process/Pipes/AbstractPipes.php
      • updater/vendor/symfony/process/Pipes/PipesInterface.php
      • updater/vendor/symfony/process/Pipes/UnixPipes.php
      • updater/vendor/symfony/process/Pipes/WindowsPipes.php
      • updater/vendor/symfony/process/Process.php
      • updater/vendor/symfony/process/ProcessBuilder.php
      • updater/vendor/symfony/process/ProcessUtils.php
      • updater/vendor/symfony/process/composer.json
      • updater/vendor/composer/ClassLoader.php
      • updater/vendor/composer/LICENSE
      • updater/vendor/react/promise/src/FulfilledPromise.php
      • updater/vendor/react/promise/src/RejectedPromise.php
      • updater/vendor/react/promise/src/UnhandledRejectionException.php
      • updater/vendor/react/promise/.travis.yml
      • updater/vendor/react/promise/phpunit.xml.dist
      • updater/vendor/react/promise/README.md
      • updater/vendor/react/promise/LICENSE
      • updater/vendor/symfony/process/Exception/ProcessFailedException.php
      • updater/vendor/symfony/process/phpunit.xml.dist
      • updater/vendor/symfony/process/README.md
      • updater/vendor/symfony/console/Formatter/OutputFormatterStyle.php
      • updater/vendor/symfony/console/Input/InputArgument.php
      • updater/vendor/symfony/console/Input/InputOption.php
      • updater/vendor/symfony/console/Output/Output.php
      • updater/vendor/symfony/console/Output/StreamOutput.php
      • updater/vendor/symfony/console/Output/NullOutput.php
      • updater/vendor/symfony/console/Helper/TableSeparator.php
      • updater/vendor/symfony/console/phpunit.xml.dist
      • updater/vendor/symfony/console/README.md
    • FILE_MISSING
      • updater/vendor/composer/autoload_static.php
      • updater/vendor/symfony/console/Helper/ProgressIndicator.php
      • updater/vendor/symfony/polyfill-mbstring/Mbstring.php
      • updater/vendor/symfony/polyfill-mbstring/bootstrap.php
      • updater/vendor/symfony/polyfill-mbstring/composer.json
    • EXTRA_FILE
      • updater/src/Tests/Http/RequestTest.php
      • updater/src/Tests/Utils/FeedTest.php
      • updater/src/Tests/Utils/FetcherTest.php
      • updater/src/Tests/Utils/RegistryTest.php
      • updater/src/Tests/Utils/CheckpointTest.php
      • updater/src/Tests/Utils/DocLinkTest.php
      • updater/src/Tests/Utils/AppManagerTest.php
      • updater/src/Tests/Utils/OccRunnerTest.php
      • updater/src/Tests/Utils/ConfigReaderTest.php
      • updater/src/Tests/bootstrap.php
      • updater/src/Tests/Controller/DownloadControllerTest.php
      • updater/src/Tests/phpunit.xml
      • updater/src/Tests/StreamInterface.php
      • updater/src/Command/DisableNotShippedAppsCommand.php
      • updater/src/Command/EnableNotShippedAppsCommand.php
      • updater/src/Command/DbUpgradeCommand.php
      • updater/vendor/ircmaxell/password-compat/lib/password.php
      • updater/vendor/ircmaxell/password-compat/LICENSE.md
      • updater/vendor/ircmaxell/password-compat/version-test.php
      • updater/vendor/ircmaxell/password-compat/composer.json
      • updater/vendor/symfony/polyfill-php55/bootstrap.php
      • updater/vendor/symfony/polyfill-php55/Php55ArrayColumn.php
      • updater/vendor/symfony/polyfill-php55/README.md
      • updater/vendor/symfony/polyfill-php55/Php55.php
      • updater/vendor/symfony/polyfill-php55/composer.json
      • updater/vendor/symfony/polyfill-php56/Php56.php
      • updater/vendor/symfony/polyfill-php56/bootstrap.php
      • updater/vendor/symfony/polyfill-php56/README.md
      • updater/vendor/symfony/polyfill-php56/composer.json
      • updater/vendor/symfony/polyfill-util/TestListener.php
      • updater/vendor/symfony/polyfill-util/README.md
      • updater/vendor/symfony/polyfill-util/BinaryOnFuncOverload.php
      • updater/vendor/symfony/polyfill-util/composer.json
      • updater/vendor/symfony/polyfill-util/Binary.php
      • updater/vendor/symfony/polyfill-util/BinaryNoFuncOverload.php
      • updater/.travis.yml
      • updater/CONTRIBUTING.md
      • updater/composer.lock
      • updater/nbproject/project.xml
      • updater/nbproject/project.properties
      • updater/box.json
      • updater/.scrutinizer.yml
      • updater/composer.json
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[updater/README.md] => Array
[expected] => 51f0f8413afe2f23c881b4e47a4595baf9b50b4e3a7de264dc3e90ec46e5a52793a7380371e06ea9195047ca5597edd72c1df8d58f634b3d349356712a702e4e
[current] => d574dd08a2dd1ec8608615e1ceb15b6894ed0c87ff99dfd24e3394e178dbcc841ad41a76cae71c4ccad02aa5f1db4651752f27b7005af6f0024028669fa2c1ab
this goes on an d on (could not even post it here)
i just have found this in your post:
Did you had a look at the mentioned documentation / link? Maybe this can help you and give you some background information about the integrity messages.
Yes i did. Tomorrow i am going to take a deeper look.
This is production and i found two other issues:
  1. All users are gone (ldap).
  2. Can’t set max upload size anywhere in GUI
  3. Is quite something. Not any of the shared folders show up to anyone before the sharer-user logs on. Quite a thing been calling for hours all project managers to login so everyone can work tomorrow…
So the integrety check is not my biggest concern atm
I had a search for the word “LDAP” on ownCloud Documentation Overview and found some notes on changes in the LDAP implementation and some references to occ commands and cron jobs which could help for 1.
Thanks, all seems fine it is just that the userdDB in ownCloud is completely empty. After a user (LDAP) logs on the UUID get’s mapped to their data and all is fine.
Annoying thing though.
Mhhh, but did you had a look at my posted reference above? From what i understand you need to run some commands / cron jobs to get this userDB filled. This won’t be done automatically according to the release notes linked above.
Mmm, well each time a consecutive user logs on all is good to normal. Did not see any commands i need to run to make that happen before hand.
File integrety is sorted, copied all the files and all good now.
I think if you follow this advice you will find some commands to make this happen beforehand:
There something like the following text was showing up in my search:
“Existing LDAP users only show up in the user management page and the share dialog after being synced”
which is pointing to a command to run.
Yes, or just the user to sign in… On initial config the users don’t appear either if i believe (if i recall that well) only after first logon.
If there is a command i would be glad to know it though.
