I used to have a cronjob downloading one of my calendars with wget
wget -q --auth-no-challenge -O /home/xxx/www/dplan.ics “https://xxx.xxxx.xxx/owncloud/index.php/apps/calendar/export.php?calid=26”
After the upgrade to 9.1.4 this does not work anymore.
I copied the Link from the webinterface (“https://xxx.xxxx.xxx/owncloud/remote.php/dav/calendars/albert/dienstplan/”) but I get this error:
“This is the WebDAV interface. It can only be accessed by WebDAV clients such as the ownCloud desktop sync client”
Is there any way to download one calendar with wget?
Thanks in advance!
a.
