- Use LDAP for authentication
- From desktop client (maybe webpage, didn’t test that) log in to server
- In Expert tab on LDAP authentication put sAMAccountName for internal username and samaccountname for UUID Attribute for Users
- In Expert tab, click Clear Username-LDAP User Mapping multiple times
users directory should be changed to username instead of UUID
The expected does happen but ALSO, multiple accounts are created, for example the user rlenzi now has 5 user accounts, 78585FAA-A5B2-4813-B400-BA36DEF0C22A, rlenzi, rlenzi_7735, rlenzi_8417, rlenzi_8619, and two directories on the server. The first directory is the UUID and the second one is rlenzi. If I try to remove any of the rlenzi users the rlenzi directory will be removed.
This is a problem because if another user tries to share a file/folder with rlenzi then they get a choice of 5 different users, all called rlenzi, and they can not figure out which one is the “real” rlenzi.
Ubuntu 18.04
Apache2
mySQL
PHP 7.2.15
10.0.10.4
Updated
Enabled:
- activity: 2.4.2
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.4.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.1.1
- market: 0.3.0
- notifications: 0.3.5
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- user_ldap: 0.13.0
Disabled: - encryption
- external
- updatenotification
- user_external
no
no
LDAP
| Configuration | s01 |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | attr:sAMAccountName |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | cn=userName,cn=users,dc=ihmc,dc=local |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | |
| ldapBackupHost | 10.10.10.10 |
| ldapBackupPort | 389 |
| ldapBase | cn=users,dc=ihmc,dc=local |
| ldapBaseGroups | cn=users,dc=ihmc,dc=local |
| ldapBaseUsers | cn=users,dc=ihmc,dc=local |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | mail |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | samaccountname |
| ldapExpertUsernameAttr | sAMAccountName |
| ldapGroupDisplayName | cn |
| ldapGroupFilter | |
| ldapGroupFilterGroups | |
| ldapGroupFilterMode | 0 |
| ldapGroupFilterObjectclass | |
| ldapGroupMemberAssocAttr | uniqueMember |
| ldapHost | 10.10.10.10 |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=person))(|(|(memberof=CN=Domain Users,CN=Users,DC=ihmc,DC=local)(primaryGroupID=513))))(samaccountname=%uid)) |
| ldapLoginFilterAttributes | |
| ldapLoginFilterEmail | 0 |
| ldapLoginFilterMode | 0 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 0 |
| ldapOverrideMainServer | |
| ldapPagingSize | 500 |
| ldapPort | 389 |
| ldapQuotaAttribute | |
| ldapQuotaDefault | |
| ldapTLS | 0 |
| ldapUserDisplayName | displayName |
| ldapUserDisplayName2 | |
| ldapUserFilter | (&(|(objectclass=person))(|(|(memberof=CN=Domain Users,CN=Users,DC=ihmc,DC=local)(primaryGroupID=513)))) |
| ldapUserFilterGroups | Domain Users |
| ldapUserFilterMode | 0 |
| ldapUserFilterObjectclass | person |
| ldapUserName | samaccountname |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 0 |
| useMemberOfToDetectMembership | 1 |
### Client configuration
**Browser:**
Safari, Firefox, Chrome
**Operating system:**
10.14.3
### Logs
#### Web server error log
#### Browser log
c) …
