System details
Device: Raspberry Pi 4
OS: Stock raspbian linux
- Edit fstab to permanently mount an external drive.
- Every time I have edited it my raspberry pi 4 just hangs saying locked out of root
Note
- I know the above may not be a owncloud issue but pretty flummoxed by this issue
- Any help would be appreciated. I have cross posted this problem in the RPi group as well.
Previously done the following successfully
- installed owncloud
- added external nvme drive using exfat
- mounted the drive with appropriate permissions
- validated that the file is actually getting written to the external drive (by owncloud) by plugging it into another computer and checking if the test files were there
Thanks much!
Raj /\
