I would like to sync my ownCloud contacts via carddav with the Contacts app in macOS Sierra.
I’m using ownCloud 9.1.3 (production) and Contacts.app Version 10.0 (1756.14.6).
The account was added with the following settings:
“advanced”
User USERNAME
Password ***
Server https://myserver.net
Path /owncloud/remote.php/dav/addressbooks/users/USERNAME/contacts/
Port 443
Use SSL
In the pervious version (El Capitan), contacts synced just fine with this setting. OwnCloud was not updated in the meantime.
The addressbook is showing up in the Contacts.app but it is empty.
Nothing showing up there.
The apache2 access log is showning:
“OPTIONS /owncloud/remote.php/dav/addressbooks/users/USERNAME/contacts/ HTTP/1.1” 200 1382 “-” “Mac OS X/10.12.2 (16C67) AddressBook/1756.14.6”
“PROPFIND /owncloud/remote.php/dav/addressbooks/users/USERNAME/contacts/ HTTP/1.1” 207 2946 “-” “Mac OS X/10.12.2 (16C67) AddressBook/1756.14.6”
forensics.log is showing
PROPFIND /owncloud/remote.php/dav/addressbooks/users/USERNAME/contacts/ HTTP/1.1|Hostmyserver.net|Accept:/|Brief:t|Authorization:Basic XXXXXX|Accept-Language:en-us|Accept-Encoding:gzip, deflate|Content-Type:text/xml|Content-Length:439|Depth:0|Connection:keep-alive|User-Agent:Mac OS X/10.12.2 (16C67) AddressBook/1756.14.6|Prefer:return=minimal
Depth:0 seems to be the issue. If I try to replicate the call using curl, I get a good XML response but with an empty addressbook. Setting Depth:1 returns all the vcards. I have no idea why the app is requesting depth:0. Maybe it’s a first probe but then the actual sync is not executed.
Any ideas what could be the problem? Maybe somebody who has a similar setup but with working synchronization could post their access logs and settings.
