Enable sharing is grayed out for SMB share
Dear friends, I have an issue “Enable sharing” checkbox is grayed out for SMB share.
When I use local share - “Enable sharing” is active.
Is there any option to enalble sharing for SMB external storage mounts (Authentication type: login credentials, save in session)?
I attached my screenshot.
- Connect SMB share with autentication (Authentication type: login credentials, save in session)as a external storage.
- Try to enable “Enable sharing” checkbox
“Enable sharing” checkbox is active
OMV6 (debian 11)
Apache (default)
MySQL
ownCloud 10.11.0 (stable) standard docker installation, idk how to check php version
fresh install
official docker yml file
Idk how to check
In integrity check: No errors have been found.
<?php $CONFIG = array ( 'apps_paths' => array ( 0 => array ( 'path' => '/var/www/owncloud/apps', 'url' => '/apps', 'writable' => false, ), 1 => array ( 'path' => '/var/www/owncloud/custom', 'url' => '/custom', 'writable' => true, ), ), 'trusted_domains' => array ( 0 => 'localhost', ), 'datadirectory' => '/mnt/data/files', 'dbtype' => 'mypass', 'dbhost' => 'mariadb:3306', 'dbname' => 'mypass', 'dbuser' => 'mypass', 'dbpassword' => 'mypass', 'dbtableprefix' => 'oc_', 'log_type' => 'mypass', 'supportedDatabases' => array ( 0 => 'sqlite', 1 => 'mysql', 2 => 'pgsql', ), 'upgrade.disable-web' => true, 'default_language' => 'en', 'overwrite.cli.url' => 'mylocalhost:8080', 'overwritehost' => 'mypublickdns:8888', 'session_keepalive' => true, 'has_internet_connection' => true, 'htaccess.RewriteBase' => '/', 'logfile' => '/mnt/data/files/owncloud.log', 'memcache.local' => '\\OC\\Memcache\\APCu', 'mysql.utf8mb4' => true, 'filelocking.enabled' => true, 'memcache.distributed' => '\\OC\\Memcache\\Redis', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => 'redis', 'port' => '6379', ), 'passwordsalt' => 'mypasswordsalt', 'secret' => 'mysecret', 'version' => '10.11.0.6', 'allow_user_to_change_mail_address' => '', 'logtimezone' => 'UTC', 'installed' => true, 'instanceid' => 'ockv9qgkspra', 'files_external_allow_create_new_local' => 'true', ) ; **List of activated apps:** I have default set of activated apps via official docker installation ``` **Are you using external storage, if yes which one:** local/smb/sftp/... local and smb **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... ### Client configuration any **Operating system:** any ### Logs #### Web server error log ``` don't know hot to find but probably not applicable ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ```
