Enabled master-key encryption accidentially
Hi folks,
don’t ask me why I did something that stupid - I hope you guys can help me out and get those files recovered.
Clicked on “Master Key” and now it seems most of the files cannot be decrypted anymore …
See detailed information below ..
Any way to fix that ?
Thanks already in advance!
  1. Basic encryption module was already enabled
  2. Enabled master key encryption accidentially
When trying to open some files now, “ERR_INVALID_RESPONSE” is given in Chrome and downloading files not longer possible
Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64 GNU/Linux
(ISPConfig 3 Setup)
Apache2
MySQL
PHP5
10.0.0.3
Updated step by step from 8.0 to 10.0 yesterday
official Website
“basic”: {
“license key”: “REMOVED SENSITIVE VALUE”,
“date”: “Fri, 27 Oct 2017 23:34:18 +0000”,
“ownCloud version”: “10.0.3.3”,
“ownCloud version string”: “10.0.3”,
“ownCloud edition”: “Community”,
“server OS”: “Linux”,
“server OS version”: “Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64”,
“server SAPI”: “cgi-fcgi”,
“webserver version”: “Apache/2.4.10 (Debian)”,
“hostname”: “XXX”,
“user count”: 22,
“user directories”: 22,
“logged-in user”: “XXX”
“config”: {
“instanceid”: “oca2ae985ecf”,
“trusted_domains”: [
“XXX”
“datadirectory”: “/var/www/clients/client6/web14/web/owncloud/data”,
“version”: “10.0.3.3”,
“dbtype”: “mysql”,
“dbname”: “web49db1”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“installed”: true,
“version.hide”: false,
“default_language”: “de”,
“defaultapp”: “files”,
“knowledgebaseenabled”: false,
“enable_avatars”: false,
“allow_user_to_change_display_name”: true,
“remember_login_cookie_lifetime”: 1296000,
“session_lifetime”: 86400,
“session_keepalive”: true,
“token_auth_enforced”: false,
“csrf.disabled”: false,
“skeletondirectory”: “”,
“accounts.enable_medial_search”: true,
“htaccess.RewriteBase”: “/owncloud”,
“versions_retention_obligation”: “auto”,
“appcodechecker”: false,
“updatechecker”: false,
“updater.server.url”: “https://updates.owncloud.com/server/”,
“has_internet_connection”: true,
“check_for_working_webdav”: true,
“check_for_working_wellknown_setup”: true,
“check_for_working_htaccess”: true,
“config_is_read_only”: false,
“cron_log”: true,
“log_rotate_size”: 20971520,
“enable_previews”: true,
“preview_max_x”: 2048,
“preview_max_y”: 2048,
“preview_max_scale_factor”: 10,
“preview_max_filesize_image”: 50,
“preview_libreoffice_path”: “/usr/bin/libreoffice”,
“enabledPreviewProviders”: [
“OC\Preview\PNG”,
“OC\Preview\JPEG”,
“OC\Preview\GIF”,
“OC\Preview\BMP”,
“OC\Preview\XBitmap”,
“OC\Preview\MP3”,
“OC\Preview\TXT”,
“OC\Preview\MarkDown”,
“OC\Preview\PDF”,
“OC\Preview\MSOffice2003”,
“OC\Preview\MSOffice2007”,
“OC\Preview\MSOfficeDoc”,
“OC\Preview\OpenDocument”
“singleuser”: false,
“tempdirectory”: “/var/www/clients/client6/web14/tmp”,
“hashingCost”: 10,
“upgrade.automatic-app-update”: true,
“debug”: false,
“mail_from_address”: “owncloud”,
“mail_smtpmode”: “php”,
“mail_domain”: “cybercomm.at”,
“theme”: “”,
“overwritewebroot”: “owncloud”,
“maintenance”: false,
“xframe_restriction”: false,
“user_webdavauth_url”: “http://XXX/remote.php/”,
“overwrite.cli.url”: “/owncloud”,
“loglevel”: 4,
“trashbin_retention_obligation”: “auto”,
“updater.secret”: “REMOVED SENSITIVE VALUE”,
“memcache.local”: “\OC\Memcache\Redis”,
“memcache.distributed”: “\OC\Memcache\Redis”,
“filelocking.enabled”: true,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379,
“timeout”: 0,
“password”: “REMOVED SENSITIVE VALUE”
“integritychecker”: {
“passing”: true,
“enabled”: true,
“result”:
“core”: {
“OC_Channel”: “stable”,
“backgroundjobs_mode”: “cron”,
“backgroundjobs_step”: “queued_tasks”,
“backgroundjobs_task”: “”,
“default_encryption_module”: “OC_DEFAULT_MODULE”,
“enable_external_storage”: “yes”,
“encryption_enabled”: “yes”,
“global_cache_gc_lastrun”: “1465290662”,
“incoming_server2server_share_enabled”: “no”,
“installedat”: “1408790307.5401”,
“lastcron”: “1509147002”,
“lastupdateResult”: “”,
“lastupdatedat”: “1509143984”,
“outgoing_server2server_share_enabled”: “no”,
“public_caldav”: “calendar/share.php”,
“public_calendar”: “calendar/share.php”,
“public_documents”: “documents/public.php”,
“public_files”: “files_sharing/public.php”,
“public_gallery”: “gallery/public.php”,
“public_shorty_qrcode”: “shorty/qrcode.php”,
“public_shorty_query”: “shorty/query.php”,
“public_shorty_relay”: “shorty/relay.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“remote_ampache”: “media/remote.php”,
“remote_caldav”: “dav/appinfo/v1/caldav.php”,
“remote_calendar”: “dav/appinfo/v1/caldav.php”,
“remote_carddav”: “dav/appinfo/v1/carddav.php”,
“remote_contacts”: “dav/appinfo/v1/carddav.php”,
“remote_contactthumbnail”: “contacts/thumbnail.php”,
“remote_core.css”: “/core/minimizer.php”,
“remote_core.js”: “/core/minimizer.php”,
“remote_dav”: “dav/appinfo/v2/remote.php”,
“remote_files”: “dav/appinfo/v1/webdav.php”,
“remote_filesync”: “files/appinfo/filesync.php”,
“remote_webdav”: “dav/appinfo/v1/webdav.php”,
“repairlegacystoragesdone”: “yes”,
“shareapi_allow_mail_notification”: “yes”,
“shareapi_allow_public_notification”: “yes”,
“shareapi_allow_public_upload”: “no”,
“shareapi_allow_resharing”: “no”,
“shareapi_default_expire_date”: “no”,
“updater.secret.created”: “1509052259”,
“vendor”: “owncloud”
Are you using encryption: yes
Google Chrome
Windows 7 Pro
no abnormal messages
{“reqId”:“uiYYMKamwdJYZg7NUOA9”,“level”:4,“time”:“2017-10-27T23:27:03+00:00”,“remoteAddr”:“78.41.113.233”,“user”:“chris”,“app”:“webdav”,“method”:“GET”,“url”:“/owncloud/remote.php/webdav/ERSTE_SCHRITTE.docx”,“message”:“Exception: {"Message":"Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.","Exception":"OC\\Encryption\\Exceptions\\DecryptionFailedException","Code":0,"Trace":"#0 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/lib\/private\/Files\/Stream\/Encryption.php(463): OCA\\Encryption\\Crypto\\Encryption->decrypt(‘ANY51q8hiEQmgBe…’, 0)\n#1 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/lib\/private\/Files\/Stream\/Encryption.php(294): OC\\Files\\Stream\\Encryption->readCache()\n#2 [internal function]: OC\\Files\\Stream\\Encryption->stream_read(8192)\n#3 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/apps\/files_external\/3rdparty\/icewind\/streams\/src\/Wrapper.php(83): fread(Resource id #93, 8192)\n#4 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/apps\/files_external\/3rdparty\/icewind\/streams\/src\/CallbackWrapper.php(91): Icewind\\Streams\\Wrapper->stream_read(8192)\n#5 [internal function]: Icewind\\Streams\\CallbackWrapper->stream_read(8192)\n#6 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/lib\/composer\/sabre\/http\/lib\/Sapi.php(78): stream_copy_to_stream(Resource id #96, Resource id #98, ‘63121’)\n#7 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(498): Sabre\\HTTP\\Sapi::sendResponse(Object(Sabre\\HTTP\\Response))\n#8 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#9 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(63): Sabre\\DAV\\Server->exec()\n#10 \/var\/www\/clients\/client6\/web14\/web\/owncloud\/remote.php(165): require_once(‘\/var\/www\/client…’)\n#11 {main}","File":"\/var\/www\/clients\/client6\/web14\/web\/owncloud\/apps\/encryption\/lib\/Crypto\/Encryption.php","Line":366,"User":"chris"}”}
do you have access to command line? Then you could try this occ command:
occ encryption:decrypt-all
It this does not work, do you have a backup?
