Encryption problem after upgrade 10.0.2 to 10.0.3
  1. Upgrade from 10.0.2 to 10.0.3
Upgrade should complete successfully
Upgrade completes with missing CHANGELOG.md problem. I fixed this and everything now appears to work except for the Files app and this is reporting an error: Invalid private key for Encryption App. Please update your private key password in your personal settings to recover access to your encrypted files.
In Settings > Personal > Encryption I try updating the private key password but this hangs on ‘Saving…’
Files cannot be accessed.
Apache2
Database: MariaDB
7.0.22-0ubuntu0.16.04.1
10.0.3
Updated from 10.0.2
Upgrade app
anonymous/gist:d228cd6f133df9f3b3f269f7759f3cf1
Enabled:
  • activity: 2.3.6
  • calendar: 1.5.4
  • comments: 0.3.0
  • configreport: 0.1.1
  • contacts: 1.5.3
  • dav: 0.3.0
  • encryption: 1.3.0
  • federatedfilesharing: 0.3.1
  • federation: 0.1.0
  • files: 1.5.1
  • files_external: 0.7.1
  • files_pdfviewer: 0.8.2
  • files_sharing: 0.10.1
  • files_texteditor: 2.2.1
  • files_trashbin: 0.9.1
  • files_versions: 1.3.0
  • files_videoplayer: 0.9.8
  • firstrunwizard: 1.1
  • market: 0.2.2
  • notifications: 0.3.1
  • provisioning_api: 0.5.0
  • qownnotesapi: 17.7.0
  • systemtags: 0.3.0
  • templateeditor: 0.1
  • updatenotification: 0.2.1
    Disabled:
  • external
  • files_antivirus
  • theme-example
  • user_external
No
Yes
No
Last few entries:
{“reqId”:“gmINmdwsLvwVOh6n5RQ2”,“level”:2,“time”:“2017-10-01T21:44:57+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“cliff”,“app”:“no app in context”,“method”:“GET”,“url”:“/owncloud/ocs/v1.php/cloud/capabilities?format=json”,“message”:“Could not decrypt the private key from user "master_f2ad378b"" during login. Assume password change on the user back-end. Error message: Bad Signature”}
{“reqId”:“EfzDYR4NrWkqjGt7mFbb”,“level”:2,“time”:“2017-10-01T21:44:58+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“cliff”,“app”:“no app in context”,“method”:“GET”,“url”:“/owncloud/ocs/v1.php/apps/files_sharing/api/v1/shares?path=&subfiles=true”,“message”:“Could not decrypt the private key from user "master_f2ad378b"" during login. Assume password change on the user back-end. Error message: Bad Signature”}
{“reqId”:“iBi1kGR2zcGZnzLRupWw”,“level”:2,“time”:“2017-10-01T21:50:11+00:00”,“remoteAddr”:“104.35.227.195”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/owncloud/index.php/heartbeat”,“message”:“Trusted domain error. "104.35.227.195" tried to access using "owncloud.16bit.co" as host.”}
{“reqId”:“Mu8AfYOtuZjSPwlPFnA7”,“level”:2,“time”:“2017-10-01T22:00:01+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“Jane”,“app”:“no app in context”,“method”:“POST”,“url”:“/owncloud/index.php/login”,“message”:“Could not decrypt the private key from user "master_f2ad378b"" during login. Assume password change on the user back-end. Error message: Bad Signature”}
{“reqId”:“JmBgFuowT1l3T604R6os”,“level”:4,“time”:“2017-10-01T22:00:54+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“Jane”,“app”:“webdav”,“method”:“GET”,“url”:“/owncloud/remote.php/webdav/CWM-JAM%20SHARED/TheCatMadeMeDoIt.pdf”,“message”:“Exception: {"Message":"HTTP\/1.1 503 Encryption not ready: Private Key missing for user: please try to log-out and log-in again","Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(85): OCA\\DAV\\Connector\\Sabre\\File->get()\n#1 [internal function]: Sabre\\DAV\\CorePlugin->httpGet(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#2 \/var\/www\/owncloud\/lib\/composer\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#3 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(479): Sabre\\Event\\EventEmitter->emit(‘method:GET’, Array)\n#4 \/var\/www\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#5 \/var\/www\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(63): Sabre\\DAV\\Server->exec()\n#6 \/var\/www\/owncloud\/remote.php(165): require_once(‘\/var\/www\/ownclo…’)\n#7 {main}","File":"\/var\/www\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php","Line":344,"User":"Jane"}”}
{“reqId”:“zI9Az68NeVLR9rTae0qY”,“level”:2,“time”:“2017-10-01T22:01:10+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“admin”,“app”:“no app in context”,“method”:“POST”,“url”:“/owncloud/index.php/login”,“message”:“Could not decrypt the private key from user "master_f2ad378b"" during login. Assume password change on the user back-end. Error message: Bad Signature”}
{“reqId”:“FdC7Ony0tzoStnKMqdwC”,“level”:2,“time”:“2017-10-01T22:02:24+00:00”,“remoteAddr”:“188.164.31.99”,“user”:“cliff”,“app”:“no app in context”,“method”:“POST”,“url”:“/owncloud/index.php/login”,“message”:“Could not decrypt the private key from user "master_f2ad378b"" during login. Assume password change on the user back-end. Error message: Bad Signature”}
{“reqId”:“IQchpu3NHMoi7fVc1Zld”,“level”:2,“time”:“2017-10-01T22:05:18+00:00”,“remoteAddr”:“104.35.227.195”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/owncloud/index.php/heartbeat”,“message”:“Trusted domain error. "104.35.227.195" tried to access using "owncloud.16bit.co" as host.”}
{“reqId”:“2kcA3Ga764LFjPl3pBZ9”,“level”:2,“time”:“2017-10-01T22:20:21+00:00”,“remoteAddr”:“104.35.227.195”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/owncloud/index.php/heartbeat”,“message”:“Trusted domain error. "104.35.227.195" tried to access using "owncloud.16bit.co" as host.”}
{“reqId”:“VbUVJkPNSWyCHpe6p7YM”,“level”:2,“time”:“2017-10-01T22:35:23+00:00”,“remoteAddr”:“104.35.227.195”,“user”:“–”,“app”:“core”,“method”:“POST”,“url”:“/owncloud/index.php/heartbeat”,“message”:“Trusted domain error. "104.35.227.195" tried to access using "owncloud.16bit.co" as host.”}
To add when we try updating the private key password in the encryption app the browser console gives the following error:
jquery.js:8630 POST
https://16bit.co/owncloud/index.php/apps/encryption/ajax/updatePrivateKeyPassword
503 (Service Unavailable)
send @ jquery.js:8630
ajax @ jquery.js:8166
n.(anonymous function) @ jquery.js:8311
updatePrivateKeyPassword @ settings-personal.js?v=f72facb9xxxxxxxxxxx546de108:12
(anonymous) @ settings-personal.js?v=f72facbxxxxxxxxxxx4546de108:58
dispatch @ jquery.js:4435
r.handle @ jquery.js:4121
VM2873:1 Uncaught SyntaxError: Unexpected token < in JSON at position 0
at JSON.parse (<anonymous>)
at Object.<anonymous> (settings-personal.js?v=f72facbxxxxxxxxxxx4546de108:22)
at j (jquery.js:3099)
at Object.fireWith [as rejectWith] (jquery.js:3211)
at x (jquery.js:8266)
at XMLHttpRequest.<anonymous> (jquery.js:8605)
Does the 503 error for updatePrivateKeyPassword suggest it’s looking in the wrong place for this function?
We gave up and did a clean install!
