Enterprise Key expired @ login using community
Enterprise activation Key still listed but not installed. just upgraded to 10.0.5
Config report apps>market> entry “Key” has a value other community servers have ‘null’
Would like to remove login message
Would you please fill the template of the forum so we can help you effectively ?
upgraded to 10.4 to 10.5.10
using ubuntu apt upgrade owncloud-files
libre office is installed
The Enterprise License Key application was checking the validity of an instance's subscription key for ownCloud Enterprise Edition. This app is obsoleted with ownCloud 10.5.0 and all functionality has been removed. You can safely disable it.
Setup in Admin App  Enterprise License Key has no disable button only Install available
login no warning messages at prelogin screen
Your Enterprise license key has expired.
Enterprise features have been disabled.
Please contact your administrator or sales@owncloud for a new license key.
@ prelogin
Error 5 access denied
Operating system: ubuntu 18.04
Web server: Apache/2.4.38
Database: 10.3.17-MariaDB-0+deb10u1
PHP version: 7.4.11
ownCloud version: 10.5.0.10 (stable)
Updated from an older ownCloud or fresh install: upgrade from fresh 10.4
Where did you install ownCloud from: Ubuntuu repositories
archive.canonical.com/ubuntu,us.archive.ubuntu.com/ubuntu/, security.ubuntu.com/ubuntu
Forgot Database
mysql Ver 14.14 Distrib 5.7.31
Thanks for reply
I guess you have a license key set (and obsolete) in the DB. You’ll have to remove it manually.
In the oc_appconfig table, with the appid enterprise_key and configkey license-key. Just remove that DB entry.
Hi jvillafanez
would you have update command for this(below was the response from the select command)
mysql> mysql> select * from oc_appconfig;
| appid | configkey |configvalue
this I found but I’m not great at mysql cli and this is a production server
| enterprise_key | license-key | demo-20200723-61950eed642dab0-864b33c7
any help is appreciated
thanks
Would this be right
update oc_appconfig SET configvalue = ‘’ WHERE appid = ‘enterprise_key’;
delete from oc_appconfig where appid = 'enterprise_key' and configkey = 'license-key';
Thank you for your time
