We do have an enterprise license running and reported in the Owncloud general tab
“The registered enterprise license key expires in xxx days.”.
Owncloud generated a notification that an update is available for the External Storage: Windows Network Drives application.
When trying to install the update either via the marketplace UI or using occ the following error occurs “Active subscription on marketplace required”.
I was able in the past to install updates and enterprise apps.
The API key is correctly entered in the marketplace, nothing changed since we get the entreprise license.
No log entry is being generated.
- Go to owncloud marketplace
- Go to updates
- Click on the update button of the app
The application should update itself
The error is displayed
Operating system: Ubuntu server 18.04 LTS
Web server: Apache2
Database: PgSQL
PHP version: 7.2
ownCloud version: 10.4.0
Updated from an older ownCloud or fresh install: updated from 10.3.x
Did I miss something on the marketplace?
Thanks in advance for the help.
AM.
