my current deployment of Owncloud Infinite State (OCIS) version 3.0.0-rc.1 on a single K3S node with the data stored locally is working fine. But when I destroy the VM with K3S and OCIS deployed and recreate the VM, reinstall K3S, redeploy OCIS and restore the local data the pod is crashing and I get the following error:
2023-05-18T07:40:51Z ERR failed to create storage space error="xattr.get /var/lib/ocis/storage/metadata/spaces/js/oncs3-public-share-manager-metadata/nodes/js/on/cs/3-/public-share-manager-metadata user.ocis.name: no data available" pkg=rgrpc request={"name":"Metadata","opaque":{"map":{"spaceid":{"decoder":"plain","value":"anNvbmNzMy1wdWJsaWMtc2hhcmUtbWFuYWdlci1tZXRhZGF0YQ=="}}},"owner":{"id":{"idp":"internal","opaque_id":"196b0e30-2266-4afa-a43d-b5de5141f01b"}},"type":"metadata"} service=storage-system status={"code":15,"message":"error creating space","trace":"00000000000000000000000000000000"} traceid=00000000000000000000000000000000
2023-05-18T07:40:51Z ERR error starting the grpc server error="unable to register services: rgrpc: grpc service publicshareprovider could not be started,: internal error: error creating space" service=sharing
Which data or environment variable do I need to restore or set to get it working? Below the needed part of my deployment.
apiVersion: v1
kind: ConfigMap
metadata:
namespace: ocis
labels:
app: ocis
data:
PROXY_TLS: "false"
OCIS_INSECURE: "true"
OCIS_LOG_PRETTY: "true"
OCIS_URL: "https://ocis.example.org"
OCIS_ADMIN_USER_ID: "..."
LDAP_URI: ldaps://192.168.0.10:636
LDAP_INSECURE: "true"
LDAP_BIND_DN: "cn=admin,dc=example,dc=org"
LDAP_BIND_PASSWORD: "..."
LDAP_USER_BASE_DN: "ou=users,dc=example,dc=org"
LDAP_USER_OBJECTCLASS: "inetOrgPerson"
LDAP_LOGIN_ATTRIBUTES: "uid"
LDAP_GROUP_BASE_DN: "ou=groups,dc=example,dc=org"
LDAP_GROUP_FILTER: "(objectclass=owncloud)"
LDAP_GROUP_OBJECTCLASS: "groupOfNames"
LDAP_USER_FILTER: "(objectclass=owncloud)"
IDP_LDAP_LOGIN_ATTRIBUTE: "uid"
IDP_LDAP_UUID_ATTRIBUTE: "ownclouduuid"
IDP_LDAP_UUID_ATTRIBUTE_TYPE: binary
GRAPH_LDAP_SERVER_WRITE_ENABLED: "true" # assuming the external ldap is writable
GRAPH_LDAP_REFINT_ENABLED: "true" # osixia has refint enabled.
# OCIS_RUN_SERVICES specifies to start all services except glauth, idm and accounts. These are replaced by external services
OCIS_RUN_SERVICES: app-registry,app-proviorgr,audit,auth-basic,auth-machine,frontend,gateway,graph,groups,idp,nats,notifications,ocdav,ocs,proxy,search,settings,sharing,storage-system,storage-publiclink,storage-shares,storage-users,store,thumbnails,users,web,webdav
apiVersion: v1
kind: PersistentVolume
metadata:
labels:
app: ocis
spec:
storageClassName: local-path
capacity:
storage: 5Gi
accessModes:
- ReadWriteOnce
hostPath:
path: "/data/ocis"
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
namespace: ocis
labels:
app: ocis
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 5Gi
volumeName: ocis-pv
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: ocis
labels:
app: ocis
spec:
replicas: 1
selector:
matchLabels:
app: ocis
template:
metadata:
labels:
app: ocis
spec:
containers:
- name: ocis
image: owncloud/ocis:3.0.0-rc.1
command: ["/bin/sh"]
args: [ "-c", "ocis init || true; ocis server" ]
envFrom:
- configMapRef:
env:
- name: ADMIN_PASSWORD
valueFrom:
secretKeyRef:
key: ocis_admin_password
volumeMounts:
- mountPath: /etc/ocis
subPath: config
- mountPath: /var/lib/ocis
subPath: data
ports:
- name: http
containerPort: 9200
volumes:
- name: ocis-data
persistentVolumeClaim:
claimName: ocis-pvc
Thanks,
Klaas
