Errant behaviour - Android client
Used to correctly open (for viewing only) text files on server; (ideally we could be able to copy and paste text as well.)
Only started when I checked ‘set as available offline’ then even though offline, would not open using app. Ive tried resetting all to unchecked ‘available offline’ no difference. Now ALL text files open Android app just show ‘Wait a moment’ and never open. Only workaround is to open them with another app.
ownCloud version:
Client version:
OS language:
Installation path of client:
logs.
  1. Client logfile: Output of owncloud --logwindow or owncloud --logfile log.txt
    (On Windows using cmd.exe, you might need to first cd into the ownCloud directory)
    (See also ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company) )
  2. Web server error log:
  3. Server logfile: ownCloud log (data/owncloud.log):
Thought I might have an answer by now. Forgot to mention, this is the premium version, not free.
Hi! sorry for the late reply
Could you provide some steps to clarify which is your problem?
