Error after Upgrade: PHP-Modul cURL not installed
  1. open the owncloud-web-page
I want to open my owncloud-start page and hope to see the login form…
I’m running owncloud on an Ubuntu 16.04-Server. Recently I added the owncloud-“Stable”-Repository an upgraded from an (working) onwcloud 9.1.6-Installation to owncloud 10 via apt-get.
I get the error messag “PHP-Modul cURL nicht installiert. Bitte frage, für die Installation des Moduls, Deinen Server-Administrator.”
In english it means as much as PHP-Module cURL is not installed. Please contact the server-admin for the installation.
My problem is that the module seems to be installed as far as I can see.
php -v gives me PHP v7.1.9 and
apt-get install php-curl says the latest version 7.1-55 is already installed.
Now I’m looking for help.
Ubuntu 16.04
Apache2
MySQL
7.1.9-1+ubuntu16.04
ownCloud version:
should be 10.0.3
Upgrade from 9.1.6
Repository:
download.owncloud.com
Log in to the web-UI is impossible.
Firefox
Chromium
Ubuntu 16.04
The module might be installed but not enabled?
run php -m an see if it is there
to enable a module try phpenmod curl
Thank’s for you reply @DeepDiver1975. php -m gives me:
[PHP Modules]
calendar
Core
ctype
curl
date
dom
exif
fileinfo
filter
ftp
gettext
hash
iconv
json
libxml
openssl
pcntl
pcre
PDO
Phar
posix
readline
Reflection
session
shmop
SimpleXML
sockets
SPL
standard
sysvmsg
sysvsem
sysvshm
tokenizer
wddx
xml
xmlreader
xmlwriter
xsl
Zend OPcache
zlib
[Zend Modules]
Zend OPcache
So it looks like the module is there.
are you by accident having php7 and php5.6 installed and apache and cli are running on different versions?
you might also want to try a reboot of apache
Yes, that might have been part of the problem.
I removed all php5.6 packages (which where indeed still installed) and now owncloud is starting again and I’m able to login.
Thank you!
