Error: Call to undefined function Aws\boolean_value() using S3
  1. Setup a S3 bucket as primary storage like described here Configuring S3 as Primary Storage :: ownCloud Documentation
  2. Used files_primary_s3
  3. Uploading a file in the storage of any user (created AFTER setup of S3) results in Call to undefined function Aws\boolean_value()
File should be uploaded
I get Call to undefined function Aws\boolean_value()
Ubuntu 20.04:
Apache
MySQL 8.x:
PHP version: 7.4
ownCloud version: 10.7 from zip source of today (see ownCloud admin page)
Updated from an older ownCloud or fresh install: no, clean setup
Where did you install ownCloud from: zip from distribution site
<?php
$CONFIG = array (
  'instanceid' => 'xxx',
  'passwordsalt' => 'xxx',
  'secret' => 'D/xxx',
  'trusted_domains' =>
  array (
    0 => 'own.xxx.xxx',
  'datadirectory' => '/mnt/web/owncloud/data',
  'overwrite.cli.url' => 'https://xxx',
  'dbtype' => 'mysql',
  'version' => '10.7.0.4',
  'dbname' => 'xxx',
  'dbhost' => 'xxx',
  'dbtableprefix' => 'oc_',
  'mysql.utf8mb4' => true,
  'dbuser' => 'xxx',
  'dbpassword' => 'xxx',
  'logtimezone' => 'UTC',
  'apps_paths' =>
  array (
    0 =>
    array (
      'path' => '/mnt/web/owncloud/apps',
      'url' => '/apps',
      'writable' => false,
    1 =>
    array (
      'path' => '/mnt/web/owncloud/apps-external',
      'url' => '/apps-external',
      'writable' => true,
  'installed' => true,
  'objectstore' => [
        'class' => 'OCA\Files_Primary_S3\S3Storage',
        'arguments' => [
            'bucket' => 'xxx-owncloud',
            // uncomment to enable server side encryption
            //'serversideencryption' => 'AES256',
            'options' => [
                // version and region are required
                'version' => '2006-03-01',
                'region'  => 'eu-central-1',
                'credentials' => [
                    // replace key and secret with your credentials
                    'key' => 'xxx',
                    'secret' => 'xxx',
Enabled:
  - activity:
    - Version: 2.6.0
    - Path: /mnt/web/owncloud/apps/activity
  - comments:
    - Version: 0.3.0
    - Path: /mnt/web/owncloud/apps/comments
  - configreport:
    - Version: 0.2.0
    - Path: /mnt/web/owncloud/apps/configreport
  - dav:
    - Version: 0.6.0
    - Path: /mnt/web/owncloud/apps/dav
  - federatedfilesharing:
    - Version: 0.5.0
    - Path: /mnt/web/owncloud/apps/federatedfilesharing
  - federation:
    - Version: 0.1.0
    - Path: /mnt/web/owncloud/apps/federation
  - files:
    - Version: 1.5.2
    - Path: /mnt/web/owncloud/apps/files
  - files_external:
    - Version: 0.7.1
    - Path: /mnt/web/owncloud/apps/files_external
  - files_external_s3:
    - Version: 1.0.0
    - Path: /mnt/web/owncloud/apps-external/files_external_s3
  - files_mediaviewer:
    - Version: 1.0.4
    - Path: /mnt/web/owncloud/apps/files_mediaviewer
  - files_pdfviewer:
    - Version: 0.12.1
    - Path: /mnt/web/owncloud/apps-external/files_pdfviewer
  - files_primary_s3:
    - Version: 1.1.2
    - Path: /mnt/web/owncloud/apps-external/files_primary_s3
  - files_sharing:
    - Version: 0.14.0
    - Path: /mnt/web/owncloud/apps/files_sharing
  - files_texteditor:
    - Version: 2.3.1
    - Path: /mnt/web/owncloud/apps-external/files_texteditor
  - files_trashbin:
    - Version: 0.9.1
    - Path: /mnt/web/owncloud/apps/files_trashbin
  - files_versions:
    - Version: 1.3.0
    - Path: /mnt/web/owncloud/apps/files_versions
  - firstrunwizard:
    - Version: 1.2.0
    - Path: /mnt/web/owncloud/apps/firstrunwizard
  - market:
    - Version: 0.6.0
    - Path: /mnt/web/owncloud/apps/market
  - notifications:
    - Version: 0.5.2
    - Path: /mnt/web/owncloud/apps/notifications
  - provisioning_api:
    - Version: 0.5.0
    - Path: /mnt/web/owncloud/apps/provisioning_api
  - systemtags:
    - Version: 0.3.0
    - Path: /mnt/web/owncloud/apps/systemtags
  - templateeditor:
    - Version: 0.4.0
    - Path: /mnt/web/owncloud/apps/templateeditor
  - updatenotification:
    - Version: 0.2.1
    - Path: /mnt/web/owncloud/apps/updatenotification
Trying to use S3…
No
No
IE/FF/EDGE/FFox/Brave/Safari
Win, Ubuntu, MacOs
{"reqId":"YL9e-nSvha@PZNORdCijPAAAAAo","level":4,"time":"2021-06-08T12:13:50+00:00","remoteAddr":"8xxx.xxx","user":"admin","app":"webdav","method":"GET","url":"\/remote.php\/dav\/files\/admin\/509_pullus.jpg?c=60bf5d516bb47&x=40&y=40&forceIcon=0&preview=1","message":"Exception: Call to undefined function Aws\\boolean_value(): {\"Exception\":\"Error\",\"Message\":\"Call to undefined function Aws\\\\boolean_value()\",\"Code\":0,\"Trace\":\"#0 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/UseArnRegion\\\/ConfigurationProvider.php(168): Aws\\\\S3\\\\UseArnRegion\\\\Configuration->__construct()\\n#1 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(203): Aws\\\\S3\\\\UseArnRegion\\\\ConfigurationProvider::Aws\\\\S3\\\\UseArnRegion\\\\{closure}(*** sensitive parameters replaced ***)\\n#2 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(174): GuzzleHttp\\\\Promise\\\\Promise::callHandler()\\n#3 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/RejectedPromise.php(40): GuzzleHttp\\\\Promise\\\\Promise::GuzzleHttp\\\\Promise\\\\{closure}(*** sensitive parameters replaced ***)\\n#4 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/TaskQueue.php(47): GuzzleHttp\\\\Promise\\\\RejectedPromise::GuzzleHttp\\\\Promise\\\\{closure}(*** sensitive parameters replaced ***)\\n#5 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(246): GuzzleHttp\\\\Promise\\\\TaskQueue->run()\\n#6 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(223): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitFn()\\n#7 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(267): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#8 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(225): GuzzleHttp\\\\Promise\\\\Promise->invokeWaitList()\\n#9 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/guzzlehttp\\\/promises\\\/src\\\/Promise.php(62): GuzzleHttp\\\\Promise\\\\Promise->waitIfPending()\\n#10 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/S3Client.php(408): GuzzleHttp\\\\Promise\\\\Promise->wait()\\n#11 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/ClientResolver.php(316): Aws\\\\S3\\\\S3Client::_apply_use_arn_region()\\n#12 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClient.php(195): Aws\\\\ClientResolver->resolve()\\n#13 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/S3Client.php(327): Aws\\\\AwsClient->__construct()\\n#14 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/AwsClient.php(440): Aws\\\\S3\\\\S3Client->__construct()\\n#15 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/lib\\\/s3storage.php(95): Aws\\\\AwsClient::factory()\\n#16 \\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/lib\\\/s3storage.php(179): OCA\\\\Files_Primary_S3\\\\S3Storage->init()\\n#17 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/ObjectStore\\\/ObjectStoreStorage.php(313): OCA\\\\Files_Primary_S3\\\\S3Storage->readObject()\\n#18 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/LocalTempFileTrait.php(66): OC\\\\Files\\\\ObjectStore\\\\ObjectStoreStorage->fopen()\\n#19 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/LocalTempFileTrait.php(48): OC\\\\Files\\\\Storage\\\\Common->toTmpFile()\\n#20 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(265): OC\\\\Files\\\\Storage\\\\Common->getCachedFile()\\n#21 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(371): OC\\\\Files\\\\Storage\\\\Common->getLocalFile()\\n#22 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(383): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getLocalFile()\\n#23 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Encryption.php(837): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->getLocalFile()\\n#24 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(371): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Encryption->getLocalFile()\\n#25 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(371): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getLocalFile()\\n#26 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Preview\\\/Image.php(49): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getLocalFile()\\n#27 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Preview.php(1129): OC\\\\Preview\\\\Image->getThumbnail()\\n#28 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Preview.php(768): OC\\\\Preview->generatePreview()\\n#29 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Node\\\/File.php(170): OC\\\\Preview->getPreview()\\n#30 \\\/mnt\\\/web\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Files\\\/PreviewPlugin.php(116): OC\\\\Files\\\\Node\\\\File->getThumbnail()\\n#31 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): OCA\\\\DAV\\\\Files\\\\PreviewPlugin->httpGet()\\n#32 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#33 \\\/mnt\\\/web\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#34 \\\/mnt\\\/web\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(330): Sabre\\\\DAV\\\\Server->start()\\n#35 \\\/mnt\\\/web\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#36 \\\/mnt\\\/web\\\/owncloud\\\/remote.php(165): require_once('\\\/mnt\\\/web\\\/ownclo...')\\n#37 {main}\",\"File\":\"\\\/mnt\\\/web\\\/owncloud\\\/apps-external\\\/files_primary_s3\\\/vendor\\\/aws\\\/aws-sdk-php\\\/src\\\/S3\\\/UseArnRegion\\\/Configuration.php\",\"Line\":13}"}
Nothing here, server side error
Re-created same config on same machine but used 10.5, as I had another installation with 10.5 working.
It works like a charm. So there is something broken in 10.7. If I have time I’ll check with 10.6.
Check Using S3 Access Point ARNs the AWS SDK for PHP Version 3 - AWS SDK for PHP in the “Configure the S3 client to use the ARN region instead of the client region” section.
You might need to include use_arn_region => true (or false) in the configuration:
  'options' => [
    'use_arn_region' => true,
    'credentials' => [
      'key' => ....
Newer version of the library might need that option. Please, read information about that option because I don’t know about the consequences of enabling or disabling that option.
There might be configuration options in your S3 server to fix this problem.
This is an option to access bucket if you decided to use access points, in that case you specify an ARN instead of the bucket name. The ARN contains the region and that setting says to use that region instead of the one in the region field.
Seems out of scope to me.
Ok, after some trial and error:
  • You do not need to create access points
  • The bucket must be specified as the plain bucket name, not the ARN
  • use_arn_region must be present and set to false
  • version must be set to latest
With these modifications the 10.7 setup works. Below the actual working snippet:
'objectstore' =[
    				'class' ='OCA\Files_Primary_S3\S3Storage',
    				'arguments' =[
    					// replace this
    					'bucket' ='bucket-plain-name',
    					'options' =[
    						'use_arn_region' =false,
    						'version' ='latest',
    						// replace this
    						'region'  ='eu-central-1',
    						'credentials' =[
    							// replace these
    							'key' ='xyz',
    							'secret' ='xyz',
I think the doc for 10.7 must be updated to reflect the required changes, the published one just fails.
if you think there is an issue in the published documentation then i think it could make sense to open an issue at GitHub · Where software is built. Posting the issue there makes sure that some one of ownCloud is noticing it because it is not guaranteed that it was noticed in this help forums.
